Forum Members: 4,741
June 12th, 2007, 04:59 AM
New Side X Side
June 12th, 2007, 10:14 AM
New Side X Side
STRAIGHT FROM ATVRIDERS.COM
The recreational sport vehicle world will never be the same again. A new breed has evolved with a mix of working UTV traits and sportier ATV genes — the Kawasaki Teryx™ 750 4x4. This new full-sized RSV is the first to have V-twin power and combines its Kawasaki heritage of efficient CVT and integrated occupant protection with superior ground clearance, cargo capacity, and sport handling to become the top performing RSV on the market. The Teryx 750 4x4 is all about recreation, yet it retains enough of its working heritage to offer amazing versatility and handy features for tackling everyday tasks.
At the core of the Teryx 750 4x4 is its strong and proven 749cc 90-degree V-twin engine, the same engine that gives the Brute Force® 750 4x4 its distinguished high performance. The mid-chassis mounted engine gives the Teryx 750 4x4 a displacement and V-twin torque advantage over its contemporaries and delivers the performance that RSV customers have been seeking. Mated to the engine is Kawasaki’s superb constant velocity automatic transmission (CVT), which transfers the power from the big V-twin to the wheels smoothly and quickly. The output of the duo provides a true sport performance, yet in a controlled manner that allows the driver to harness the full potential of the Teryx 750 4x4.
Naturally, big power demands a chassis to compliment it and once again the Teryx delivers with an ideal width body – narrow enough to be useful and able to navigate the trail but wide enough to be stable and handle the healthy output from the V-twin. Its large-diameter, thin-walled tubular frame offers the necessary rigidity without performance draining weight, and all in an arrangement spacious enough to fit two adults comfortably.
The Teryx 750 4x4 shares the long A-arm and narrow frame concept of its sport brethren to give it the maximum travel while minimizing wheel camber change. Featuring adjustable Kayaba suspension with gas-charged shocks, the sport-performance focused suspension of the Teryx 750 4x4 is designed to remain controlled even at top speed.
When the terrain requires it, the driver can activate 4WD with a simple servo-control switch. Further traction management is achieved via an ATV-style front differential control activated with a hand lever that functions like a rear hand brake and lets the driver select how much the wheels are locked together. The rear wheels stay locked and always turn together — much like a sport ATV — allowing the Teryx to slide around corners easier in a drift style.
It continues its dominance in the field with new 26-inch Maxxis tires developed specifically for the Teryx 750 4x4 that enable superb forward and sliding traction. The tall tires offer good rough terrain handling and contribute to its class leading ground clearance and ability to overcome obstacles.
A fast RSV would not be good without having equally capable stopping power and Teryx 750 4x4 delivers. It employs a combination of dual 200mm discs up front and a sealed wet brake in the rear. The front brakes are tucked into the wheels for protection from debris and their 27mm twin-piston calipers are rigid-mounted for optimum feel and control. The advantage of the sealed rear brake is most apparent when it’s able to keep working even in the wettest or muddiest of environments.
Featuring bucket seats and retractable three-point seat belts that keep the driver and passenger strapped in snugly, the Teryx 750 4x4 also has plenty of shoulder and leg room to provide a comfortable ride. It also has foot guards designed into the steel floor boards and body along with a padded steering wheel that is positioned low for better control.
However, the Teryx 750 4x4 isn’t all play and no work. It is equipped with a 500-pound capacity cargo bed that is ideal for recreational users, yet versatile enough for work and hauling with tie down hooks in all four corners and comes with a cargo net to keep the goods secure. The Teryx 750 4x4 can also pull the load with its 1300-pound towing capacity.
Rider comfort and conveniences increase even more on the Teryx 750 4x4 LE, with the addition of a digital meter with dual trip meters, clock and hour-meter, half-windshield, hard top and dual retractable cup holders. The LE also features a tilting cargo bed with gas assist, which gives the tilting bed a boost.
When the sun drops the fun or work doesn’t have to stop with the dual 40W headlights showing the way and dual rear taillights letting it be seen. An eight gallon fuel tank allows it to operate longer and cover more distance so the journey isn’t cut short either.
The Teryx 750 4x4 is built tough with scratch resistant Thermo-Plastic Olefin (TPO) bodywork and steel skid plates underneath to shield the engine from the ride stopping obstacles.
A large selection of authentic Kawasaki Accessories are available for the 2008 Teryx 750 4x4 are available through Kawasaki dealers. As with all off-highway vehicle recreation, Kawasaki encourages RSV drivers to drive responsibly and to respect the environment.
Kawasaki Motors Corp., U.S.A. (KMC) markets and distributes Kawasaki motorcycles, ATVs, personal watercraft and utility and recreational sport vehicles through a network of more than 1,500 independent retailers, with an additional 7,700 retailers specializing in power products and general purpose engines. KMC and its affiliates employ nearly 2,400 people in the United States, with 400 of them located at the Irvine, California headquarters.
Kawasaki’s tagline, “Let the good times roll.™”, is recognized worldwide and the brand has become synonymous with powerful, stylish motorcycles for over four decades. Information about Kawasaki’s complete line of recreational products and Kawasaki affiliates can be found on the Internet at www.kawasaki.com.
Engine:
* The 90-degree 749cc V-twin engine is the largest, most powerful engine in its class
Closer look at the
Tyrex 750 4x4's Drivetrain
Positioned mid-ship for optimum front/rear balance – good for power slides and cornering control
* Straight intake tracts and 34mm downdraft carburetors enhance power delivery throughout the rpm range
* Radiator is compact and placed high in the chassis for better protection against mud and debris
* Ducts located by the cargo bed direct cooling air to the engine
* Aluminum cylinders are Electrofusion-plated for light weight, long wear and excellent heat dispersion
* Engine can be started in any gear when the rear brake is applied
* Electronically controlled Kawasaki Engine Brake Control helps to slow the RSV when traversing steep down hills
Transmission/Selectable Four-wheel-drive:
* CVT features high and low ranges, plus reverse
Two- or four-wheel-drive operation at the press of a button
Combined with the engine power characteristics, provides instantaneous acceleration
* Rider can select two- or four-wheel-drive operation by pressing a button located on the dash
* Limited-slip front differential reduces steering effort under normal four-wheel drive operation, while Variable Front Differential Control permits rider to distribute torque equally to left and right front wheels for maximum traction via a hand lever
* Rear wheels are locked and always turning together for cornering control
Chassis:
* Large-diameter thin-walled tubular steel frame
* Only RSV with integrated occupant protection
* First with sport performance-focused suspension – low-speed comfort not a main design priority
* Wide track provides excellent stability and chassis has 11.2 inches of ground clearance
* Long dual front A-arm suspension and narrow frame concept provides 7.5 inches of travel and features adjustable gas-charged Kayaba shocks
* Independent rear suspension provides the best balance of rider comfort and handling at high speeds, and adjustable gas-charged Kayaba shocks with reservoirs provides 7.25 inches of travel
* Chassis offers the right balance of bump absorption while limiting understeer
* Able to tackle corners in either a drift or grip style and operate beyond the limits of its rivals
Misc. Features:
* Dual front 200mm disc brakes with two-piston 27mm calipers and Kawasaki’s sealed, oil-bathed, multi-disc rear brake system provide maximum stopping power in all conditions
* Front discs are recessed in wheels for protection from debris
* Good rough terrain performance and obstacle clearance with 26-inch Maxxis tires specially built for the Teryx 750 4x4
* Tread design enables both controlled sliding and forward traction
* Bucket seats with retractable three-point seat belts
* Foot guards designed into the floor and body
* Padded steering wheel positioned low for better control
* Body work is made of high-gloss scratch resistant Thermo-Plastic Olefin
* Steel floor boards and engine guards for maximum protection
* Dual 40W headlights and dual taillights
* Cargo bed has 500 lb capacity, tie down hooks in all four corners and cargo net standard
TERYX 750 4x4 LE Additional Features:
* Digital Meter
* Dual retractable cup holders
* Hard top
* Half-Windshield
* Tilting cargo bed with gas assist
Specifications:
Engine Liquid-cooled, 90-degree, four-stroke V-twin
SOHC, four valves per cylinder Displacement 749cc Bore x stroke 85 x 66mm Compression ratio 8.8:1 Carburetion (2) Keihin CVKR-34 Starting Electric / Digital DC-CDI Transmission Continuously variable belt-drive transmission with high and low range, plus reverse, and Kawasaki Engine Brake Control Final drive Selectable four-wheel drive with Variable Front Differential Control, shaft Frame type Large diameter, thin-walled, high-tensile tubular steel Front suspension / wheel travel Adjustable dual A-arm with gas charged shocks / 7.5 in. Rear suspension / wheel travel Adjustable Independent Rear Suspension (IRS) with gas charged, reservoir shocks / 7.3 in. Front tires Maxxis 26x8-12 Rear tires Maxxis 26x10-12 Front brakes Dual hydraulic discs with 2-piston calipers Rear brake Sealed, oil-bathed, multi-disc Overall length 115.7 in. Overall width 58.3 in. Overall height 75.4 in. Wheelbase 75.8 in. Ground clearance 11.2 in. Lighting (2) 40W headlights, (2) TK W taillight, TKW stoplight Cargo bed capacity 500 lbs, 44.1 W x 32.7 L x 12 in. H Towing capacity 1,300 lbs. Dry weight TBD Fuel capacity 8 gal. Instruments R/N/P/4WD indicators, water temp and oil pressure lamps, digital meter (LE only) Standard Colors Sunbeam Red, Woodsman Green, REALTREE™ Hardwoods Green® HD MSRP Standard/LE TBD Warranty TBD[/b][/b]
June 12th, 2007, 11:13 AM
New Side X Side
that looks so much like a rhino but better i like it
650 Brute SRA
27' Executioners
HMF Penland
Moose Module
Snorkeled
1 5/8 spacers per side
June 12th, 2007, 11:19 AM
New Side X Side
I heard they were going to the 750 but I cant believe they didnt do efi. I also heard they were changing the name and glad they did.
June 13th, 2007, 02:01 AM
New Side X Side
Nice! This one looks like it wants to have a little more fun! More aggressive look than the Mule, especially with a nice set of rims and tires! The Power is also a very nice upgrade.
'06 Brute Force 650 4x4i
26" Maxxis Bighorns, 12" ITP SS 106,
Direction 2 Overfenders, Diamond Bumper,
Floor Board Trim, Engraved Billet Shifter,
Copperhead VDI, Full Muzzy Exhaust, DynoJet kit
Clutch Springs (EPI maroon primary, stock secondary)
Intake Splash Guard, Swaybar Removed....
June 13th, 2007, 08:56 AM
New Side X Side
Total Rhino knockoff if you ask me. Nice to see the Brute motor in there though!
June 13th, 2007, 12:23 PM
New Side X Side
Nobody did.
The grille, hood, bumpers, tires, cage, seats, harness, dash, bed, side covers, suspension, frame, transmission and motor are different.
So I guess you could call that a "total" knockoff.
June 14th, 2007, 09:40 AM
New Side X Side
My bad...didn't mean "total" knockoff...hehehe. It's a super looking machine. I wish they did a fuel injected model though. It's gotta be awesome. If Yamaha releases a fuel injected 700 with power steering, it will be hard to beat. I'm still wondering what the others have up thier sleeve.
As of right this second, I'd take the Kawie!
June 14th, 2007, 01:00 PM
Guest
New Side X Side
Watch for the Arctic Cat 950 Prowler to be released.
I got word from the dealer show guys today that it's coming in 09.
the Arctic Cat Thunder Cat EFI 950cc v-twin Atv will be out by the end of this September. 188 pounds of torque!!!
I'm glad that Kawy finally made a SxS I have a 916cc Bruteforce motor that'll bolt right in there sitting on my bench. in my quad it made 81 RWHP about 119 crank HP. that'll get that big boy moving. it was much too fast for my Vforce to harescramble with. but in that machine. it'd be like a 4x4 off-road Corvette.
I hope they make it EFI!!
John
June 14th, 2007, 08:49 PM
New Side X Side
I hope this isn't a photoshop joke. I guess I need to start buttering up the wife. This would make a great christmas gift!
Stock 06 750
