Forum Members: 4,741
September 9th, 2008, 03:02 PM
Jetting help
I am installing a LRD slip on, and doing the 12 hole mod on my 650 bruteSRA. I also have a VDI cdi. 1200 ft elevation....any suggestions on where to start with my jetting? Thanks
October 14th, 2008, 08:26 PM
Re: Jetting help
Stumper,
Not sure if the carbs are the same on the 650 SRA as the Prairie 650, but if they are, I would try jetting up one size (142 front, 145 rear) and shim the needles.
October 16th, 2008, 10:49 AM
Re: Jetting help
no 12 hole mod on that ute.
that's for Vforce's
150-152 and put on a Napa hose mod* closed airbox
John
VFORCEJOHN (570)773-1721
October 16th, 2008, 11:54 AM
Re: Jetting help
He could look at getting an EHS air box lid.* That would flow more air and still keep water/ mud out.
jetting after ehs mud lid
swabber30 |
Brute Snorkeling |
3 |
May 22nd, 2009 12:14 AM |
jetting still not right
hillrod660750 |
Brute Engine & Drivetrain |
1 |
December 24th, 2007 02:21 PM |
Jetting Help
Smokeshow |
2 |
May 22nd, 2007 08:33 PM |
