July 22nd, 2008, 09:32 PM
engine doesn't start
alright im working on my buddies prairie 700 04. has been sunk at least 4 times. anyways this time is was running good. he shut it off and went to start it up again and it turned over and stopped with a clunk. starter sounded jammed. i have taken a wrench to the crank shaft it rotates about 3/4 of a shaft rotation both ways and stops with a clunking metal sound. i have taken the starter out. and popped the rear valve cover. i have a couple of ideas. what should you suggest i try first as its not easy to get to everything.
dropped valve
flywheel teeth done
timing chian on front valves gone
or someting eles?
July 22nd, 2008, 11:18 PM
can't remember what it was, but camo's prarie did the same thing out at st. a's, and i know he's already torn into it so i'm pretty sure he'd be able to tell you.
2007 YFZ450
Houser +2 ST A-Arms (2005 YFZ front end) w/
Elka Compression adj. shocks.Yoshi Carbon Fiber Full Exhaust,DG Nerfs w/built-in heal guards,EHS Racing lid Jetted and NCVQ adjustable needle.
SOLD: 04 Predator 500 TLD.
July 23rd, 2008, 07:18 AM
If he does not turn off the gas when he shuts it down, it is possible that it is hydrolocked. Gas flows into the cylinders and locks them. Try pulling the plugs and then turning it over. See if any gas comes out. Then try it again.
Good luck.
July 25th, 2008, 02:49 PM
Re: engine doesn't start
i have pulled both plugs and nothing still... but hey krazyk* camo prairie is that is name on here or ?
July 25th, 2008, 03:25 PM
his sn is CamoKVF700* He's the guy with the turbo V, also has a couple of praries.* haven't seen him around since the change over, but i'd shoot him a pm if i was you, just tell him i thought he might be able to help.
2007 YFZ450
July 25th, 2008, 03:29 PM
damn he shows up as "guest" on this new site. so i can't pm him. i hope he comes on quick. as its driving me nutz to figure out the problem
July 25th, 2008, 09:53 PM
he's on kawieriders all the time
2007 YFZ450
July 28th, 2008, 03:25 PM
shoot me a pm and i'll tell you how to get ahold of him.* won't let me put the link in here?? >:(
2007 YFZ450
July 28th, 2008, 05:38 PM
alright thanks guys i appreciate it. and i think by also reading the post on nyroc too. that sounds likes its someting internal. so im goign to tell him to take it to the dealer. as i dont' have all the special tools to do it. have a feelings its a spun bearing
04 prairie 700 no start
Won't start
mudlift |
Brute Engine & Drivetrain |
12 |
January 1st, 2009 06:12 PM |
Jets were do I start
misfitrider |
17 |
October 27th, 2008 11:37 PM |
Won't START!
bruteboy101 |
Brute Chassis & Electrical |
3 |
April 30th, 2007 11:28 AM |
no start
Bunnycop |
5 |
April 4th, 2007 12:50 AM |
