January 15th, 2010, 06:35 PM
MOOSE MODULE 2008 BRUTE FORCE 750
Looking for the Moose module for 2008 Brute force 750 EFI for a friend of mine.
Hoping someone has one laying around after maybe upgrading to a DYNA or VDI
Thanks
2008 Brute Force 750i (Stock)
Rear Sway bar Energy Suspension Upgrade
Bison Front Bumper
DG5 Module
Heated grips and Thump
Front and Rear Winch
Maxxis Bighorns
Full Set of HDPE Skids
January 15th, 2010, 09:40 PM
hmmm, sorry to burst your bubble, but Im about 98% sure the moose module will not work with an EFI machine.
someone will correct me if im wrong, but Im certain they were only for the 05-07 750's, 05-current 650i's and arctic rat 650 H1's
January 15th, 2010, 11:14 PM
I know of no moose module /CDI that fits anything past 2007, so....the fuel injected Burtes take a different controler.
January 16th, 2010, 12:02 AM
i was not aware of that, i will have to tell him to get a dg5 module like mine
Bison Front Bumper
DG5 Module
Maxxis Bighorns
January 16th, 2010, 12:04 AM
What do you guys mean?
You tell me what is at the bottom of the picture.... And yes its an 08
January 16th, 2010, 12:08 AM
I had 2 of them that failed. Work great in the 2007 and later but the 2008 ones and up don't seem to be holding up yet.
January 16th, 2010, 12:15 AM
So...what does the Dj modules control and what is the Moos controling in your 08?
January 16th, 2010, 12:25 AM
Everything!!! Actually the Power Commander 3
The Dynojet Power Commander plugs inline with your bike’s stock fuel injection system. It uses OEM (original equipment manufacturer) style connectors making installation easy and quick. The Power Commander III USB allows a full range of fuel adjustment, as much as +/- 100% over stock. Adjustments can be made either with a Windows based computer or by using the face plate mounted button adjusters. No permanent changes are made to the bike’s system. Once the unit is removed the bike reverts to its stock settings.
Power Commander 3 Ignition Module
The Ignition Module is connected to the PCIII USB with it’s built in expansion port link and communicates via a CAN interface. As in the case of the Power Commander, the Ignition Module uses OEM style connectors to plug in-line of the stock ignition harness so no cutting or splicing is required. The Ignition Module uses “direct coil driver technology” and allows a high degree of timing adjustment. In the Power commander Control Center Software the user is able to advance or retard the ignition curve up to 10 degrees based on throttle position and RPM. It is also possible to alter the timing for each cylinder individually if necessary.
Moose Module
Basicly is giving mine more timing down low. It use to have to be easy until 20 mph then you could gun it with no problem. But if you would floor it out of the whole it would give it a funky reading and wouldn't let it rev like it should the whole way up the RPM range. VFJ and I both wonder if we had but in the degree thing in would we have used the moose module? Probably. The EFI is finyky
January 16th, 2010, 12:36 AM
so basicly,it does not do for the 08's as it did for prior carb models ? when i ask the kawi dealer if moose was making an aftermarket cdi for the 08 yet,they told me it was not available.i know when my friend put one on his 07,it unleashed the beast.removing all stock limiters.
 DAMN YOU MUST B FAST.....
CAUSE I WAS HAULIN' ASS WHEN I PAST U !!
2008 BF750i *2008 RHINO *2009 RAPTOR 90 *2004 NISSAN TITAN *
2007 TAHOE Z71 *2006 WEEKEND WARRIOR FS2300*1998 DOUBLE
WIDE TRAILER.....PRIORITIES,PRIORITIES...
January 16th, 2010, 03:36 AM
the Velocity Devices Copperhead CDI box is quite popular. if you go into google, just search VDI Copperhead
its around 500 bucks, but apparently it will knock you socks off
2008 brute force 750 dynatek, 2009 brute force power module, 2010 brute force suspension upgrades, 700 brute force front diagram, brute force 2008 750i shock adjustment, brute force 750 computer upgrade, brute force 750 fuel injected, brute force 750i power module, brute force moose module, does a 2007 brute force have efi or carbs, is the 07 650 brute force fuel injected, moose brute force rear bumper, moose module brute force, moose module for brute force, moose module for brute force 750, moose module on 2010 brute force 750, moose timing box brute force, perma tune ignition module diagram, timing a brute force 750, what to look for brute force 750
