May 25th, 2010, 03:35 PM
broken tie rod end
Yesterday, I was doing 40-50 km/hr down a trail and realized I didn't have any steering    Something which always makes me nervous flying down roads and trails. Royal Distributing up here in Canada sells All Balls tie rod upgrade kits which includes 2 x 12mm rods and all new ends. Anybody using them and are you happy with them? What are others using for tie rod ends?
May 25th, 2010, 08:08 PM
Just out of curiosity...what kind of riding do you normally do and what were you doing prior to losing your tie rod? BTW-I haven't had to replace a tie rod, but I just replaced a wheel bearing in my Grizzly with an All Balls bearing and it seemed like a very good quality part. Equal to or better than OEM.
May 25th, 2010, 08:29 PM
All Balls are Ok. I use Diamond Gs. ASR also makes a great set. SS ATV, a sponser her also has stainless sets.
May 25th, 2010, 09:24 PM
The main thing is that you didn't get hurt. I'm still on my stock rods and ends but their are several good after market rods and ends. I mostly just trail ride. When I replace mine I'll probably find some beefed up ends and keep the stock rods as a "crumple zone". If everything is beefed up, then something else has to break.
May 25th, 2010, 10:11 PM
I'm riding in southwestern Ontario Canada, so I'm into all sorts of terrain. One trail will be sand and water. Another will be rocks, but every trail has the necessary ingredient --- MUD! Considering I have 2000 Kms on my 2008 and I ride with a fairly aggressive group of guys, I was surprised the OEM ends lasted this long.
May 25th, 2010, 10:32 PM
Im running a set of ASR pro X series on my brute. I had nothing but bad luck with the stock stuff. never bent a rod, but I had two ends come apart at the socket while ripping down a trail.
May 28th, 2010, 12:00 PM
Same as Brian.... I am running ASR's and never have a problem now. Love them
July 31st, 2010, 08:57 PM
Just installed Alls Balls ends on my Brute today.....broke one on the weekend so they all got changed.Haven't had a chance to try them yet but they are a good product.Hayneser75 i've got a question...when you installed the Alls Balls did you use the washers that were mounted with the stock rod ends?Thank Vern
August 3rd, 2010, 10:02 AM
I don't believe I did. I used what came in the All Balls packaging...
So far, I don't have any complaints about the rod/end kit. They seem to be standing up to the Canadian Shield
August 7th, 2010, 12:10 PM
Which of the 2 do you guy see as better? ASR or ALLS BALLS? just managed to bend a tie rod lastnight as it tossed me way off my Brute haha good thing it only grabbed my boot as it went onto its side! looking to upgrade to a better set tho!
God Hates A Coward!
12mm tie rod ends brute force 650i, all balls brute force tie rod ends, all balls tie rod ends, broken tie rod end, brute force 650i tie rods, brute force all balls tie rod, brute force broke tie rod, brute force broken tie rod, brute force tie rod end upgrade, brute force tie rod upgrade, home made tie rod end tools, losing a tie rod, royal distributing tie rods
