Brute Central Forums » General Forums » General Discussion » Engine oil for your truck
Old January 31st, 2010, 01:42 AM   #11
Wildman1988's Avatar
Whats wrong with the fram filters? I'm using the correct # filter it calls for
Wildman1988 is offline
Old January 31st, 2010, 02:26 AM   #12
fram filters are made with cardboard end caps inside the filters that have been known to break down and cause the oil filter to do absolutly nothing, and in some cases, the cardboard particales plug the oil pump or oil gallerys in the engine.. they are an extremly terrible filter IMO
you can usually buy a much higher quality oil filter from napa, purolator, wix or less than the frams also.
Old January 31st, 2010, 09:28 AM   #13
I am sorry wildman but I heard the same thing. Fram was always a trusted brand for me too untill those reports. You can just spin it off and another one on and just add a little oil. I use and like the best the Purolator pur-One. Its even a little longer then stock. I also liked the Kawi, K&N & Napa. I didn't like the Mobile1 .
Old January 31st, 2010, 12:41 PM   #14
Along with Amsoil engine, gear, and ATF oils, I also use their EAO oil filters on my truck, Brute, and ZX-10R. Nice thing, the Brute and ZX-10R take the same filter. I also run the Amsoil EAA air filter on my truck.
2007 Brute 750i
Warn XT-30 Winch
Fender Flares
richracer1 is offline
Old January 31st, 2010, 03:06 PM   #15
Thanks for the info. i guess I'm gonna have to kiss FRAM goodbye. Time to change over the truck and wheelers before something happens.
Old January 31st, 2010, 06:03 PM   #16
I think their car/truck filters are OK, just the bikes
Old January 31st, 2010, 06:28 PM   #17
Coolwizard's Avatar
I've been using Penzoil in everything for many years with no problems. like someone else said, I don't think it's so much the brand of oil but the frequency of maintenance.
I used fram filters on atvs' and street bikes for numerous years, also with no problems. After I heard the reports I stopped using them on my toys. I've got the purolator filters on everything now because they are a little longer and hold a little more oil. I still use fram filters on my trucks and cars.
Coolwizard is offline
Old January 31st, 2010, 09:00 PM   #18
wildman..if you want to have a good read about oil filters, check this out
Oil Filters Revealed - MiniMopar Resources
i will only run purolators, wix, or baldwin filters on anything I own.
The Following User Says Thank You to BrianMc For This Useful Post:
NMKAWIERIDER (January 31st, 2010)
Old January 31st, 2010, 10:10 PM   #19
Wow...good info Brian...Thanks!
Old February 1st, 2010, 03:40 PM   #20
Coolwizard's Avatar
[QUOTE=BrianMc;118167]wildman..if you want to have a good read about oil filters, check this out
Wow! after reading that, I won't be using those crappy Fram filters on my truck anymore either!
Go Back   Brute Central Forums » General Forums » General Discussion
