May 22nd, 2008, 11:07 PM
BIGHORNS 2.0
Any one have em ? i never had bighorns, i hear they are good and now a few pounds lighter. Would 26x9x12 front and 26x11x12 fit with out rubbing my gas tank and fender.Also are they ok for a stock clutch ?
May 24th, 2008, 12:20 AM
BIGHORNS 2.0
I got 26 X 14 Bighorns on my Polaris RZR. Their Awesome. That thing goes anywhere my brute goes and that has 29.5" Outlaws. I'm Strongly considering puttin them on the brute cause they ride so much nicer.
SIZE MATTERS!!!
May 24th, 2008, 02:36 PM
BIGHORNS 2.0
'06 Brute Force 650 4x4i
26" Maxxis Bighorns, 12" ITP SS 106,
Direction 2 Overfenders, Diamond Bumper,
Floor Board Trim, Engraved Billet Shifter,
Copperhead VDI, Full Muzzy Exhaust, DynoJet kit
Clutch Springs (EPI maroon primary, stock secondary)
Intake Splash Guard, Swaybar Removed....
May 25th, 2008, 02:40 PM
BIGHORNS 2.0
February 18th, 2009, 03:08 PM
<div class='quotetop'>QUOTE (BRUTETHERAPY @ May 23 2008, 03:07 AM) <{POST_SNAPBACK}></div>
Any one have em ? i never had bighorns, i hear they are good and now a few pounds lighter. Would fit with out rubbing my gas tank and fender.Also are they ok for a stock clutch ?[/b]
no rubbing, no clutch work needed I have the 26x9x12 front and 26x11x12 setup on a +2+5 itp rim
Whats the difference between peanut butter and Jam?
07 kfx90
07 kvf750
07 wolverine {will someone please steal this thing}
February 18th, 2009, 08:04 PM
<div class='quotetop'>QUOTE (BruteJockey @ May 25 2008, 11:40 AM) <{POST_SNAPBACK}></div>
That link didn't work but here is one that does:
http://www.maxxis.com/MotorcycleATV/ATV-Ut...n-20-Front.aspx
February 18th, 2009, 10:14 PM
I think I will go with these tires when I upgrade. Do they run large like the original bighorns? If so I'm thinking 25x10x12(22.7 ponds per tire) mounted on all for corners. If they don't run large I may go with 26X11X12s on all four corners.(25.7 pounds per tire)
3000Lb Viper Winch.
Highlifter Radiator.
Highlifter Springs.
ASR X Series Tierods.
Rox Risers Solex Handlebar.
Drat Fab Lowering Kit.
VFJ Stage 3 Goodness.
EHS Airbox Lid.
Maroon Primary Spring.
</span></span></span>
February 18th, 2009, 10:33 PM
A guy I know runs a wide low profile only when he races. They are radials and come in 10s,11s or 12s wide and they have 25 all the up to 30s . He runs the 25x12x12s all the way around on a lowered Can Am. He uses Terras on another set of rims on the trails though.
February 28th, 2009, 04:08 PM
I just got back from the local shop and they had a set of these in 25's and they feel light! the tread also felt soft, I'm thinkin bout them in a 26, bet they would be good on hard rocky trails :goofy:
March 1st, 2009, 12:54 AM
They Rock. I recommend them to everyone. their all all round perfect tire for any type of terrian and they ride like your on a cusion of air. Maxxis measures them Big here's 26's up besides my 29.5
SIZE MATTERS!!!
27 big horns on bruteforce 750 images, 27 bighorn originals on a brute 750
