Old March 6th, 2009, 06:43 PM   #41
gusmx5's Avatar
Aaa this must be good because if you weigh my friends 28" they must weigh 10 kilos at least each(that is 20 pounds)...
It is a big drag for the atv.Did you notice the difference of the stock dunlops with the after market tires?
Huuuge!!!
gusmx5 is online now
Old March 6th, 2009, 07:04 PM   #42
<div class='quotetop'>QUOTE (gusmx5 @ Mar 6 2009, 03:43 PM) <{POST_SNAPBACK}></div>
Huuuge!!![/b]
Well, from what I see, the regular 26x12x12 Big Horns are 30.6 lbs ea and the 26x11x12 Big Horn 2.0s are 25.7 lbs ea. Thats a lot less then these 27x11x14" XTRs at 33.3 lbs ea.
Yeah, I can pick up the whole stack of all four stock tires & rims but can hardly pick up two of these aftermarkets. So more then twice the weight for sure.
Old January 14th, 2010, 11:11 AM   #43
JVDChuck's Avatar
I have the original bighorns on my machine. I have the 25's on and they measure at 26.5. A buddy purchased the 2.0's and they are exactly 25". I like myine though, there a little heavier but I can fly through the snow with no problems. The lug is quite a bit smaller on the 2.0's
http://i847.photobucket.com/albums/a...0/IMG_1477.jpg
2008 Brute Force 750 EFI, Maroon Primary, Maxxis Bighorns, Moose Front Bumper,Kympex Passenger pegs, Dynateck CDI
1977 Yamaha DT400
2008 Dodge Ram 3500, 6.7 CTD, 4" lift,
JVDChuck is offline
Old January 20th, 2010, 07:44 PM   #44
BRUTETHERAPY's Avatar
WoW..Thanks for the reply's everyone ! I have been gone for a seriously long time..I ended up getting ITPs XL..And they are coming off real soon..I hate them..
BRUTETHERAPY is offline
Old January 20th, 2010, 08:24 PM   #45
Might check out what's on the market now. There is a lot of talk about the PitBulls and GBC's. All good. Many are moving away from the bighorns now.....markets are fickle. Still a great tire though.
Old January 20th, 2010, 09:19 PM   #46
Yeah, I have been looking at those,along with the Mudwolfs..although the wolfs have the same tread pattern as what i have now. Other sites praise them...You have thoughts on these two ? Also now i realize i need extra ground clearance..Probably been posted before but 27s on a BF650 SRA<-- Stock exempt rims. i have ss106 i think..Will 27s fit ? without scrubbing..I know im going to loose power ..and will probably have to do something about the clutch right ?
Thanks,
Old January 20th, 2010, 10:09 PM   #47
Thanks,
Well...Mudwolfs are a Carlisle tire I believe..and I won't buy anything Carlisle. Just a bad experience. Probably an OK tire but not for me. As for the rest, well it will depend on what you want to do mostly.
I would think the 27s should be fine especialy on aftermarket rims. I have 27s ...granted on a 750, but there's no way they can rub. And yeah..you are probably going to want to do spme clutch work. At least a maroon primary and maybe a little stronger secondary. I finaly ended up with a Dalton Violet which is perfect for mine.
27 big horns on bruteforce 750 images
27 bighorn originals on a brute 750
Bighorns vs. Zillas Brutesmitty Brute Tire & Wheel Combos 7 July 15th, 2009 12:38 AM
Traded Swamps for Bighorns BruteJockey Brute Tire & Wheel Combos 8 September 15th, 2008 04:42 PM
25" or 26" bighorns? tackfeest Brute Tire & Wheel Combos 5 March 16th, 2008 03:24 PM
27" bighorns on my 07 brute, will they fit with out a L Tj Craig Brute Tire & Wheel Combos 9 March 9th, 2007 03:20 PM
