Old March 13th, 2008, 06:19 PM   #1
Default Tire Size?
I want to upgrade from the stock tires on my 07 brute 750. What is the largest size I can go with without having to do any mods? (spacers, lift kit ect.) Any feedback would be helpful thanks.
bocephus322 is offline
Old March 13th, 2008, 08:00 PM   #2
Default Tire Size?
28" will fit with no trouble....but when going to a bigger size tire you should add a clutch kit
www.StarCityATV.com www.Big13ATVClub.com www.WoolwichWheelers.com
07 Can-Am 800 Outlander H.O. XT - HMF Yellow Pipe-Power Commander-Dalton Clutch Kit-ITP SS 106 W/ 27" XTR's-Ricochet Full Skids-Hot Grips-2500 Warn Winch-Mobil 1 MX-4T
07 Can-Am 800 Outlander H.O. - HMF Red Pipe-Power Commander-Dalton Clutch Kit-ITP SS 106 W/ 27" XTR's-Ricochet Full Skids-Hot Grips-2500 Warn Winch-Mobil 1 MX-4T
05 750 Brute Force - HMF Pipe-Dynojet-Dalton Clutch Kit-ITP SS112 W/ 27" XTR's-Penlock-Skull Shifter-Twin Air-Mobil 1 MX-4T
05BruteForce750 is offline
Old March 14th, 2008, 01:55 AM   #3
Default Tire Size?
I have an 07 BF750 as well and I put on 28" Swamp Lites with no cluth kit and it made my quad loose lots of low end. I then put in my Daulton Clutch Kit and it made a big difference. The reason for saying this is that my cousin has the same quad but has 28" Mud Bugs on his and he didn't need a clutch kit in his. He had no power loss after putting them on. You just have to watch how aggressive the tires are as well to also dictate if u are going to have power loss or not.
Just my 2 cents worth hope this helps a little bit.
bf750red is offline
tire size vs clutch spring doys750i Brute Engine & Drivetrain 9 December 27th, 2008 06:36 PM
TIRE SIZE & CLUTCHING RANDALLPINK7 Brute Tire & Wheel Combos 4 December 5th, 2008 07:39 PM
Tire size and front diff Drew T Brute Engine & Drivetrain 3 April 9th, 2008 02:07 AM
which tire size is overall best? oohyeah4 Brute Tire & Wheel Combos 15 February 19th, 2008 06:23 AM
Ture TIRE SIZE ?? MUD LITES ? Tj Craig Brute Tire & Wheel Combos 2 March 15th, 2007 09:34 AM
