Old January 7th, 2008, 12:33 AM   #1
Default rear brake cable
Any body have a problem with their rear brake cable seizing on. More so when cold. Are these serviceable at all
pepr is offline
Old January 7th, 2008, 06:57 AM   #2
Water gets inside the cable & freezes , you'll have to take the cable off and hang upright then with a cable luber start introducing some wd40 to the cable & let it drip down the inside of the sleeve . Some people have claimed to drip antifreeze or tranny fluid . I just back off on the rear brake adjustment & run without rear brakes till I can get to them .
Sure would have been better if Kawi put a hydrolic slave cylinder on the rear diff.
bruteforze is offline
Old January 7th, 2008, 03:57 PM   #3
Mudcon's Avatar
i just replaced my cable cause it also rusts inside of it. new cable was alot easier to deal with.
2010 Teryx Sport
Mudcon.com
Mudcon Production ATV Videos
Mudcon is offline
Old January 7th, 2008, 06:43 PM   #4
Mine did it after 3 months old , In the northeast it gets a little cold & the water inside the cable housing freezes , If you leave you're parking break on it will be frozen & the only way to undo it is to back off on the cable adjustment .
Old January 20th, 2008, 06:06 AM   #5
Just get a cable luber tool and flush the thing with WD40. Then push some good cable lube through it which is designed to repel water. I went through this the first year with my machine. Has not given me a problem since.
06 BF 650i Camo
27" Mud Lites
Warn 3.0ci
Ricochet skids
gardingh is offline
Old January 30th, 2008, 04:25 PM   #6
Just get a cable luber tool and flush the thing with WD40. Then push some good cable lube through it which is designed to repel water. I went through this the first year with my machine. Has not given me a problem since.[/b][/b]
Where can a person get a cable luber tool?
Canadian Kawie is offline
Old January 30th, 2008, 09:10 PM   #7
GatorTom's Avatar
Where can a person get a cable luber tool?[/b][/b]
You can get them at most auto parts stores. You can also find them on Ebay. Just search for cable luber.
GatorTom is offline
rear brake fattiremike Brute Tire & Wheel Combos 5 March 17th, 2008 08:53 PM
rear brake cable BRICKLAYER Brute Tire & Wheel Combos 1 December 10th, 2007 07:09 PM
Rear brake/ parking brake adjustment BluelightSpecial Brute Tire & Wheel Combos 1 June 19th, 2007 11:08 PM
