Old August 9th, 2007, 01:37 AM   #1
Default Tire Sizes and PSI
I am just sorta wondering what everyone else runs in their tires based on size.
mine = 27" Super Lites 7.5psi all around
buddy of mine = 27" Mud Lites 4psi all around
Also is there an advantage of more or less air, or does it depend on situation?
2007 Brute Galaxy Silver | FCP 800 | glass pack exhaust | Snorked | SSAtv 2" lift | Douglas Rattlesnakes 26" Outlaws | FCP clutch kit |
Scoobs is offline
Old August 9th, 2007, 10:15 AM   #2
It really depends on ride style and prefference. If you are agressive in the corners you will want to run a bit more air. If you want a softer ride you will want a bit less air. Both the numbers you gave are well within reason. I personally run 5 psi. all the way around in my 27" XTRs as this seems to be a good compromise for my riding style and ride prefference. If you are too soft you will get more sidewall flex and it will feel sloppy in the corners. If you are too high it will dance at higher speeds because the tires balloon and you are running on a smaller patch and a little bump can bounce the tire out of contact with the ground rather than being absorbed by the tire.
Bottom line is, try different pressures and see what you like.
Boloiii is offline
Old August 9th, 2007, 10:27 AM   #3
30" zillas 10psi on all 4
<div align="center">07 blue bf 750: piped, clutched, zillaed, snorked and gorillizied
TEAM XXL
VP CANADA CHAPTER
click here for pics
</div>
jester is offline
Old August 9th, 2007, 10:53 AM   #4
05-BF-750's Avatar
26" swamp lites 4psi front 3.5psi rear
27" executioners 3psi all around
Brute Force 650 sra
KFX V-Force 700
05-BF-750 is offline
Old August 9th, 2007, 12:01 PM   #5
28 inch bugs 10 psi on all 4
07 750i
28x12 bugs all the way around
Full Muzzy, 2500 warn
Moose module, Bull Snorks
SSATV Bumper, Floorboard trim
rabbit is offline
Old August 9th, 2007, 01:38 PM   #6
27" Bighorns at 7 psi front and rear. I never would have considered 7 psi, but I had some wobble and size problems at 4-5 psi so I called Maxxis and 7 psi is what they suggest to run them at. And at 7 they are all perfectly sized and have no wobble.
07 750 - Lime Green
BigReub is offline
Old August 9th, 2007, 07:05 PM   #7
BruteJockey's Avatar
26" AMS Swamp Fox Plus tires. 9" wide in the front with 6 psi, 12" wide in the back with 6.5 psi!
'06 Brute Force 650 4x4i
26" Maxxis Bighorns, 12" ITP SS 106,
Direction 2 Overfenders, Diamond Bumper,
Floor Board Trim, Engraved Billet Shifter,
Copperhead VDI, Full Muzzy Exhaust, DynoJet kit
Clutch Springs (EPI maroon primary, stock secondary)
Intake Splash Guard, Swaybar Removed....
BruteJockey is offline
Old August 10th, 2007, 08:35 AM   #8
05-BF-750's Avatar
Hey BruteJockey, you have any pix you can shair of your Brute with the fox tires on? I'd really like to see these tires on a Brute.
Brute Force 650 sra
KFX V-Force 700
Old August 10th, 2007, 05:28 PM   #9
You bet 05-BF-750, I'll post some up on Saturday(Aug. 11) if that works for you!!
Old August 12th, 2007, 02:29 PM   #10
Here's a few of those pics of the AMS Swamp Fox Plus tires on my Brute!
air in brute force 650 tires
brute force 650 sra best tires bighorns or swamp foxes
brute force 650 tire sizes
how to remove a tire on a brute force 650
maxxis bighorn size 7 psi
psi for brute force
what size executioner can i fit on a bruteforce650 sra
OEM Wheel Sizes, Offsets, Tires Sizes and Bolt Patters phreebsd ATV Accessories 1 January 16th, 2009 10:10 PM
rims sizes oohyeah4 Brute Tire & Wheel Combos 3 January 23rd, 2008 06:35 PM
Speedo & tire sizes pscheibler Brute Tire & Wheel Combos 4 June 21st, 2007 10:05 AM
