July 29th, 2010, 10:05 AM
#11
I run 26" Big Horns on my '10 Brute and 26" Bighorn 2.0 on my '08 Brute. Both are IRS models and using ITP wheels so clearance is not a problem for me. Both tires are excellent trail tires. The 2.0 rides smoother, but the regular looks better and probably performs better in mud.
August 5th, 2010, 08:45 PM
#12
BIG HORNS ON!!
2005 BRUTE FORCE 650 SRA
FULL MUZZY
DYNATEK CDI
NAPA HOSE MOD
K & N AIR FILTER / UNI FILTER
PINK PRIMARY & BLACK SECONDARY
40-PILOTS 150-FRONT & REAR MAINS
2 SHIM ON EACH NEEDLE 2.75 TURNS ON A/F SCREWS
26x9x12 & 26x12x12 BIGHORNS
ITP108SS RIMS (4+3 FRONTS 2+5 REARS)
August 5th, 2010, 08:52 PM
#13
Looks realy great on her. Nice!!
August 6th, 2010, 01:41 PM
#14
It looks really good!
August 7th, 2010, 04:46 PM
#15
They look great on your machine. Very bad -ss! :-)
October 19th, 2010, 02:27 AM
#16
are those the 2.0's or the original bighorns? how do they ride, do they shake?
October 19th, 2010, 01:45 PM
#17
Those are original Bighorns. I have both tires. The original Bighorns ride decent. The 2.0 rides better. No shake with either, at least with mine.
2005 brute force rim offset, 2006 bute force offset bighorn tire and wheel kit, 26x9x12 all the way arounbd on brute force, 26x9x12 big horns on all four, bf 650 sra 25 inch tire clutch mods, brute force 27 inch bighorns, brute force 650 28 bighorns, brute force 650 sra new wheels and tires, brute force 650 sra to tippy, brute force bighorns, brute force sra bighorns, brute force with 25 inch bighorns, maxxis bighorn 25x10x12, running 26x9x12 on all four wheels and brute force, sra bighorns, what bigger tires can i put on my 2005 brute force, wheels for brute force 650 sra 27 inch tires, will 12 wide bighorns fit stock brute 750 wheels?, will 26x9x12 tires fit stock brute force rims?, will bighorn 2.0 26x9x12 fit sportsman
