Originally Posted by bruteboy
ok i just adjusted my carbs 2.5 turns out with 150 front and 155 rear dyno jet jets.and know when i get on it it smokes white smoke and sputters when i am full throttle. also it does want to idle right what coulld be wrong? thanks guys
Well, as you can see from the part of the chart, DJs # 150 &155 are equal to Keihin's 165 and 170+. As I recall, the stock jets were 152 & 155. I don't know what or who told you to put those in, but They are way too big. Even with a full system and those pistons, they would be too big. If you are going to use those dynojet jets, then you need to be closer to 142/144 or 144/146. Ok, thats for the highend. Now the idle problem. 2.5 is a good spot on the a/fs. If the float levels are still the same, then the only carb-related cause for a problem is a vacuum leak. The most common problem a Brute has is the clamps that hold the carbs to the boots and the boots to the heads cut the boots if tighted too much. Done it myself... twice. Check your valves too just to be sure.
Width------Keihin # -- DynoJets # -- Mikuni #
0,0540---- 140--------- 130--------- 121,9
0,0550---- 142,5------- 132--------- 123,8
0,0560---- 145--------- 134--------- 125,6
0,0570---- 147,5------- 136--------- 127,5
0,0580---- 150--------- 138--------- 129,4
0,0590---- 152,5------- 140--------- 131,3
0,0600---- 155--------- 142--------- 133,1
0,0610---- 157,5------- 144--------- 135,0
0,0620---- 160--------- 146--------- 136,9
0,0630---- 162,5------- 148--------- 138,8
0,0640---- 165--------- 150--------- 140,6
0,0650---- 167,5------- 152--------- 142,5
0,0660---- 170--------- 154--------- 144,4
0,0670---- 172,5------- 156--------- 146,3
0,0680---- 175--------- 158--------- 148,1
0,0690---- 177,5------- 160--------- 150,0
0,0700---- 180--------- 162--------- 151,9
0,0710---- 182,5------- 164--------- 153,8
0,0720---- 185--------- 166--------- 155,6
0,0730---- 187,5------- 168--------- 157,5
0,0740---- 190--------- 170--------- 159,4
