Old April 23rd, 2010, 12:54 PM   #1
bruteboy's Avatar
Default breaking axels
do you guys think 29.5" laws will brek axels if you dont jump your quad and ride in low when you hit the mud?
bruteboy is offline
Old April 23rd, 2010, 04:32 PM   #2
The brutes can and do break axles. It is said that if it can't unload the tork through spining the tires, and it can't slip the belt, then the axles will twist enough to snap especialy with lift kits because the tork isn't even as the axle turns. It peaks and valleys depending on the CV position. Heavier duty axles help, but then if it can't break an axle, the differencial, driveline or beavel is next. So pick your poision. The Brute won't care..the engine is going to turn and if it can't spin the tires or slip the belt, its just going to break the weakest link between the crank and the tires.
Old April 23rd, 2010, 05:57 PM   #3
DLB
DLB's Avatar
I've read that the Brute Force has the strongest stock axles of any ATV on the market. You are much more likely to break a belt than an axle...which imo is better than breaking the latter. On the other hand, my Grizzly has the strongest belt setup on the market, therefore the axles are likely to break first.
2009 Brute 750
Almond Secondary | ASR bushings | Big Gun Evo System | Bighorns | GoPro HD Hero2 | HDPE Skids | ITP SS 312s | MSD FI Charge | Powermadd hand-guards | Prothane Sway Bar Bushings | Snorkels | Streamline Steering Stabilizer | Symtec Heated Grips | Temp Gauge | Viper Max 4500 | My Garage
http://www.youtube.com/WVGrizzly | http://www.youtube.com/ElkRiverOffRoad
DLB is online now
Old April 23rd, 2010, 11:10 PM   #4
Yeah but...tell that to the hundreds of Brute owners that have broken several axles using the same belt.
I'm sure there are a few stories about axles floating around here.
Old April 24th, 2010, 12:38 PM   #5
bruteboy's Avatar
you think i would be better off with the 28" laws?
bruteboy is offline
Old April 24th, 2010, 01:19 PM   #6
It's not going to matter much if it hooks-up and its in the right position at the wrong time.
Hay, is that you over on MIMB that's done...and selling your Brute? He has the same screen name anyway.
Old April 24th, 2010, 02:02 PM   #7
bruteboy's Avatar
na idk what minb is lol
bruteboy is offline
Old May 27th, 2010, 11:44 AM   #8
kawasaki1's Avatar
Default 29.5" Outlaws
I pop wheelies and have done plenty of mudding in last 2 years with my Outlaws and just a few days ago found out my a-arm bushings are shot.I have not broke no axles but i am Knocking on wood.Hopefully it doesn't happen soon cause money is tight.
Red 2006 750 Bruteforce,highlifter ECU,HMF Exhaust,29 1/2"Outlaws on Red Platoon rims,Kenwood stereo,2 6x9 Memphis speakers,2 4" Memphis speakers,300 watt Boss amp,speaker box and stereo box,2 Ammo boxes for storage,Ice chest and ice chest rack and snorkels.
kawasaki1 is offline
Old May 30th, 2010, 01:51 AM   #9
nar
I don't know how you guys can ride hard with big tires and not destroy axles. I only have 26s and have another axle that sounds like it is near breaking, sounds like the same side that broke before, left rear. Front end is clattering, sounded like a spider broke off and got into something else... I am about ready to sell these tires and get some 25s.
2008 BF 750
26 inch innova mud gear, motorsports alloys
5000+ elevation
nar is offline
Old June 1st, 2010, 09:58 PM   #10
bruteboy's Avatar
gotta keep a eye on bearings and what kind of noise is the rear axle making?
bruteboy is offline
