Old February 19th, 2010, 10:27 AM   #1
Trever's Avatar
Default Wheels
Who else makes wheels for ATV's other then ITP?
Trever is online now
Old February 19th, 2010, 10:39 AM   #2
DPS
DPS's Avatar
Mine are made by Vision.. I like them, and my offset is wide so no spacers needed, But makes for a muddy ride
2006 Brute 750 4x4i
Gorilla axles, 28's, Full Muzzy, K&N, DJ Jet kit, Warn 2.5 Winch, Skid Plates, 2.5" snorkel
DPS is offline
Old February 19th, 2010, 11:12 AM   #3
Douglas Wheels, and Maxxis are a couple of others.
Old February 19th, 2010, 11:26 AM   #4
All those and STI
Old February 19th, 2010, 11:28 AM   #5
Thom's Avatar
Check out the motosports wheels. I am looking at those for my next purchase. They make some pretty wild wheels.
Thom is offline
Old February 19th, 2010, 11:31 PM   #6
skip nay's Avatar
Here is a few.
ATV Wheels from ITP, STI, Vision, Super Grip, and Motosport Alloy
MOTOSPORT ALLOYS | Custom ATV Wheels, tires and accessories
skip nay is offline
Old February 20th, 2010, 10:27 AM   #7
Trever's Avatar
Thanks for the links!!! Now to find something that will fit my SRA! It seems like aftermarket wheels are built more for IRS machines.
Old February 20th, 2010, 12:03 PM   #8
Originally Posted by Trever View Post
Thanks for the links!!! Now to find something that will fit my SRA! It seems like the aftermarket wheels are build now a days are built more for IRS machines.
Do you know the stock offset for the SRA? You know...I think there is a pretty good stock wheel chart over on MIMB and...if you go down about 6 posts on the lug chart thread, there is a link to a site with more stock wheel offsets. I will look and post here if I get the chance...at work today. I would think as long as you don't increase the first number more then 1" you should be OK. It may be more the width of the tire that comes into play with the SRA. I don't know for sure though.
Old February 22nd, 2010, 02:08 AM   #9
SWBF900's Avatar
i went with the Motosport Wheel this time, needed a change from ITP.
These are the M9 Patroit's.
EAGLE EYE HID's
VHOLDR 1080P Helmet Cam
Ramsey 2500# Wireless Winch
Ricochet Belly Plates
CHUCK750 HDPE footwell Skids
API a/arm Guards
Powermadd Handguards
EHS Mudder Lid
UNI Air Filter
PBR Diff Lock Button
AMStar MX-Pro Tie Rods/Ends
Trail Tech Voyager GPS unit
SWBF900 is online now
Old February 22nd, 2010, 02:19 AM   #10
SWBF900's Avatar
The Can-hams use the same bolt pattern as the SRA Prairie, so you can find the wheels you need.
I had the ITP SS312 wheels on my short owned Outlander 800.
EAGLE EYE HID's
API a/arm Guards
EHS Mudder Lid
UNI Air Filter
msa wheels sra 650
