January 10th, 2010, 03:41 PM
#41
i also thought about seeing if they make an adapter to go from the 137 to the 110 bolt pattern[/QUOTE]
Did you find an adapter? I'd like to have one also so I could run my stock 750 rims (110 pattern) on my prarie (137 pattern). If anyone sees an adapter like this please let me know.
January 10th, 2010, 04:48 PM
#42
what are you running on the Prairie now?
January 10th, 2010, 07:28 PM
#43
Did you find an adapter? I'd like to have one also so I could run my stock 750 rims (110 pattern) on my prarie (137 pattern). If anyone sees an adapter like this please let me know.[/QUOTE]
Here ya go Coolwizard. Here's one place. Also,check with Mudlift. He owns SS ATV plus, a sponsor here He has spacers, and can probably get you what you need....and at a discount!
http://www.kgmotorcycletires.com/atv_wheel_spacers.htm
January 11th, 2010, 01:38 PM
#44
NMK, Thanks for the info.....it looks like with the price of adapters, I'd be just as well off buying a set of rims. The 1998 prarie has stock rims on it now. I actually have 2 sets for it. The problem is that the stock rear rim is only 10" diameter which really limits tire choices. I didn't want to buy another set of rims since I don't ride it that much.
January 11th, 2010, 01:43 PM
#45
Yeah they are pricy. Maybe just a set of basic 12" steel rims. Arn't they about 45 bucks each?
January 13th, 2010, 08:02 PM
#46
ok so i ended up buying the 12" ss108 wheels, and to make it so i could afford tires too i got the 26 in sti mud trax xl, not sure how good they are but they have to be better than the factory dunlops
January 13th, 2010, 10:40 PM
#47
Oh...they will be.
January 13th, 2010, 11:26 PM
#48
Originally Posted by NMKAWIERIDER
Hmm...must have changed the pattern over the years. I think mine is 4/110. Anyway, not sure which is the best way to go on offset other then with any single weel bearing setup like the Brute has, candlevering offsets should be avoided. From what I have always been told, if you must have offset, have the higher number toward the inside not the outside.
I was thinking he was going after the wrong bolt pattern as well, so I checked ITP's website and the 650 Brute Force SRA does in fact use the 4-137 bolt pattern. Oh I forgot to mention, I put the black SS108s on my 07 red Brute.
2007 Brute 750i
Warn XT-30 Winch
Fender Flares
January 14th, 2010, 12:57 AM
#49
Yeah I found that too. I never knew that.
January 14th, 2010, 07:51 AM
#50
it didnt help either that the ss108 backspace listings were listed wrong for my quad too made it hard to pitcure them fitting but all is good getting 4+3 for the front not the 5+2 like listed
27 12x12 swamp lites on stock rims, splash tube
