Brute Central Forums » Brute Forums » Brute Tire & Wheel Combos » will 26x12 mudlites fit rear
Old November 8th, 2009, 07:44 PM   #11
Originally Posted by Geno2 View Post
If I was to get after market wheels, what offset should I get? Going on the rear of a 06 brute force.
Offset numbers are from the outside flat surface of the hub to the inside first then to the outside. So something that says it has the offset of 5+2 means that this is a 7" wide rim with five inches to the inside of the hub and two inches to the outside. Vision uses a different system, but uses a back-set(BS) number that tells the offset to the inside. Looks like per the ITP wheel charts that they like to put the big number inside and the little outside on the Brutes. Most of the rims out there are 7" so you can have any offset you want as long as it does not exceed 5" to the inside but remember the more you stick outside, the wider the machine is. Looks like 5+2 is used a lot with ITP as well as 4+3. I might like the 4+3 as it makes it a bit wider and more stable. I selected Vision wheels because they make an 8" rim in a 14". I forget but I think these are centered at 4+4. Anyway, for bearing life, try to keep it centered or the larger number first....if you can.
Hope that helped.
Old November 8th, 2009, 08:34 PM   #12
5" offset i beleive
Old November 11th, 2009, 08:54 PM   #13
yeah i have 26inch 12 X 12 on mine and it fits fine. actually makes my hook up nicer and easier to paddle though mud
08 Brute Force 650i
LRD EXHAUST
TWIN AIR FILTER
CDI IGNITION CHIP
EPI SEVER DUTY BELT
SS112 RIMS
26" MUDLIGHT exl's
ASR HEAVY DUTY TIE RODS AND ENDS
OGIO BAGS
2000lb SUPERWINCH
FULL SKIDS
GO GREEN
BForce650i is offline
Old November 11th, 2009, 10:38 PM   #14
My Brute has 26-12-12 Swamplites on ITP SS108 wheels on the rear and 26-9-12 on the front. The wheels are 5-2 for front and rear. Anyway, I have no problems with tire to tank interferance.
2007 Brute 750i
Warn XT-30 Winch
Fender Flares
richracer1 is offline
Old November 14th, 2009, 10:24 AM   #15
Went with 26-10-12's on the rear. Gonna use the stock rims. Would have liked to gone w/aftermarket aluminum wheels and 26-12-12's, but just don't have the cash. Can't wait ant longer, as the stock tires are bald/worn out. They also have been half- assed repaired in the past and wont hold air for more than a few hours. Getting new tires mounted this afternoon, and looking forward to a day of riding on Sunday. Thanks for the input/help.
Geno2 is offline
Old November 14th, 2009, 02:07 PM   #16
Good show.
I run 27x10's on all four corners. kinda nice to be able to rotate the tires when thoes rears are getting low on tread!
Old November 14th, 2009, 07:16 PM   #17
Originally Posted by BrianMc View Post
Good show.
That's what I am going to do too...except with 26s.
Old November 14th, 2009, 10:56 PM   #18
Yeah I think I will go 26's next time around also. i dont really have a need for 27's...im sure the 26's smoke just as good LOL
Old November 15th, 2009, 12:18 AM   #19
Yeah and probably be cheaper to replace....and easier on the belt too...hehe
replace tire brute force larger
