Forum Members: 4,739
Total Threads: 5,993
Brute Central Forums » Brute Forums » Articles » Secondary clutch spring compressor.
LinkBack Article Tools Display Modes
Old
shawn3806's Avatar
shawn3806 shawn3806 is offline
by shawn3806 November 9th, 2008
Does anyone have a pics of one they made. Dont want to drop the $75.00 buy EPIs. If I remember right all it is is a piece of all thread, couple washers, couple nuts and a pipe cap cut for removal of circlp right?
Views 1108 Comments 22
Total Comments 22
Comments
Old November 9th, 2008, 05:17 PM   #2
Jv2cat's Avatar
Correct. It is not hard to make at all. I made one myself but I don't have any pictures.
Jv2cat is offline
Old November 9th, 2008, 05:21 PM   #3
<div class='quotetop'>QUOTE (nadep python @ Nov 9 2008, 08:41 PM) <{POST_SNAPBACK}></div>
Does anyone have a pics of one they made. Dont want to drop the $75.00 buy EPIs. If I remember right all it is is a piece of all thread, couple washers, couple nuts and a pipe cap cut for removal of circlp right?[/b]
Right. That's about all it is. I bought an EPI and it's just a piece of angle iron to grip in the vice, some 1/2" all thread welded to the angle iron, some nuts and washers and comp-ring that is sized to push the head away from the circlip. I'll get a pic and post it for you when I get a chance. If I new that this was all it was, I'd a made my own too.
Old November 9th, 2008, 09:56 PM   #5
sailorgriz's Avatar
Or you can do it the redneck way, like I did. Take two Jorgenson woodworking clamps, lock 'em into a Black & Decker workmate vice top thingy, and use the Jorgenson's to compress the OUTSIDE edges of the flanges. Works like a charm. Not something I'd want to use everyday, but for the once in 2 years I 've needed it, it was fine.
I'd show the pix, if I could figure out where I put them.
You could actually do the same thing with any sort of woodworking clamps. The idea is to be able to compress to parts together--whcihs is what woodworking clamps are make to do.
sailorgriz is offline
Old November 9th, 2008, 10:18 PM   #6
shawn3806's Avatar
Thanks guys, BF Freak you da man! I'll be stopping by the hardware store after work tomorrow to pick up all the stuff I need.
Old November 9th, 2008, 10:23 PM   #7
mudlift's Avatar
Look here in the garage to see the one I made. You just need some angle iron, flat bar & some nutz & bolts. I have done 10 or so with the one I made.
http://www.kawiecentral.com/forums/index.p..._item&CID=6
mudlift is offline
Old November 9th, 2008, 10:32 PM   #8
Glad to help NP. And you don't need that lower nut and washer. You just use the upper anyway.
Seems like I used mine about four times in the last two years, so it was nice to have.
Old November 9th, 2008, 10:47 PM   #9
You can also make from a piece of threaded 5/8 rod, a couple of nuts and oversized washers, and a PVC end cap with a cut out in it. Total cost will be about $5.00. I have used mine many times, on my Prairie and vtprairie's BF, with zero problems.
Secondary clutch spring compressor.-spring_compressor_parts1.jpg   Secondary clutch spring compressor.-secondary_clutch_spring_compressor1.jpg
Adirondack Man is online now
Old November 9th, 2008, 11:38 PM   #10
MetalMan's Avatar
Yep easy to make. Heres mine. I used a 2" steel cap.
MetalMan is offline
Go Back   Brute Central Forums » Brute Forums » Articles
brute compressor rod
how to make a clutch spring compressor
how to make a secondary spring compressor
how to make clutch spring compression tool
how to make secondary clutch compression tool
how to make secondary spring removal tool
make clutch spring compressor
metalman welding
secondary clutch spring compressor
secondary spring compression tool
spring compression tool for secondary clutch
Article Tools
Similar Articles
Article Author Forum Replies Last Post
Changing Secondary Clutch Spring jaup09 Brute Engine & Drivetrain 21 November 22nd, 2008 05:19 AM
Anyone have a link to a how to for secondary clutch spring? ojcool Brute Engine & Drivetrain 2 August 8th, 2008 11:19 PM
Secondary clutch spring mossy Brute Engine & Drivetrain 9 July 30th, 2008 08:35 PM
Secondary clutch spring compressor tool Aussiebrute Brute Engine & Drivetrain 6 April 26th, 2008 12:09 PM
Secondary clutch spring compressor. shawn3806 Brute Engine & Drivetrain 0 December 31st, 1969 08:00 PM
