Brute Central Forums » Brute Forums » Articles » Secondary clutch spring compressor.
LinkBack Article Tools Display Modes
Old
shawn3806's Avatar
shawn3806 shawn3806 is offline
by shawn3806 November 9th, 2008
Does anyone have a pics of one they made. Dont want to drop the $75.00 buy EPIs. If I remember right all it is is a piece of all thread, couple washers, couple nuts and a pipe cap cut for removal of circlp right?
Views 1109 Comments 22
Total Comments 22
Comments
Old May 10th, 2009, 07:32 PM   #21
MetalMan's Avatar
For some reason the pic went bad. Here it is again.
MetalMan is offline
Old August 20th, 2009, 01:10 PM   #22
Greg G's Avatar
I know its an old thread but I am a fairly new brute owner and I have a question about the home made compressors. If you weld the all thread to some angle so it can be clamped in a vise why is everyone using the other nuts and washers? I understand why there is a nut and washer on the top of the cap but why underneath? I got the scrap and a new steel cap sitting around just waiting on another rainy day.
Thx
Greg G
Greg G is offline
Old August 20th, 2009, 02:12 PM   #23
<div class='quotetop'>QUOTE (Greg G @ Aug 20 2009, 10:10 AM) <{POST_SNAPBACK}></div>
Thx
Greg G[/b]
Mine from EPI came with those extra nuts too. I think they are for another applications that they are needed, but they are not needed for use as the secondary compresser, just the one on top for the compression of the cap.
Just a side note, did you drill a hole through the angle iron, then slip the rod through and weld it on the back side and the top side, or just butt-welded it to the iron? I am asking because of a thread on another site where a butt weld didn't hold and it came apart on the guy. The EPI compresser was drilled and welded on both sides. Just FYI.
Go Back   Brute Central Forums » Brute Forums » Articles
brute compressor rod
how to make a clutch spring compressor
how to make a secondary spring compressor
how to make clutch spring compression tool
how to make secondary clutch compression tool
how to make secondary spring removal tool
make clutch spring compressor
metalman welding
secondary clutch spring compressor
secondary spring compression tool
spring compression tool for secondary clutch
Article Tools
Similar Articles
Article Author Forum Replies Last Post
Changing Secondary Clutch Spring jaup09 Brute Engine & Drivetrain 21 November 22nd, 2008 05:19 AM
Anyone have a link to a how to for secondary clutch spring? ojcool Brute Engine & Drivetrain 2 August 8th, 2008 11:19 PM
Secondary clutch spring mossy Brute Engine & Drivetrain 9 July 30th, 2008 08:35 PM
Secondary clutch spring compressor tool Aussiebrute Brute Engine & Drivetrain 6 April 26th, 2008 12:09 PM
Secondary clutch spring compressor. shawn3806 Brute Engine & Drivetrain 0 December 31st, 1969 08:00 PM
