Brute Central Forums » Brute Forums » Articles » Secondary clutch spring compressor.
LinkBack Article Tools Display Modes
Old
shawn3806's Avatar
shawn3806 shawn3806 is offline
by shawn3806 November 9th, 2008
Does anyone have a pics of one they made. Dont want to drop the $75.00 buy EPIs. If I remember right all it is is a piece of all thread, couple washers, couple nuts and a pipe cap cut for removal of circlp right?
Views 1109 Comments 22
Total Comments 22
Comments
Old November 13th, 2008, 01:45 AM   #11
GatorTom's Avatar
The one I made is almost exactly like Metalman's.
GatorTom is offline
Old November 16th, 2008, 10:38 AM   #12
brutalized's Avatar
I used a 2 1/2" hole saw instead of a steel pipe cap on the one I made. It already has a hole drilled in the top and it's easier to cut away the window, just grind the teeth off and you're done.
brutalized is offline
Old November 16th, 2008, 03:05 PM   #13
MetalMan's Avatar
Thats a good idea with the hole saw for someone that has an old one laying around. The steel cap is hard to cut away with out the right tools no doubt.
I now have a window cut on both sides of my steel cap instead of just one like it is in the pic i posted. With a window on both sides it MUCH easier to get the clip on and off.
MetalMan is offline
Old November 16th, 2008, 06:04 PM   #14
brutalized's Avatar
<div class='quotetop'>QUOTE (MetalMan @ Nov 16 2008, 03:05 PM) <{POST_SNAPBACK}></div>
With a window on both sides it MUCH easier to get the clip on and off.[/b]
I think I'll cut the other side too. I'll need to tighten the belt soon and the clip was a hassle to get out from just one side.....thanx
Old November 16th, 2008, 11:33 PM   #15
Bubbasoffroad2's Avatar
I think this thread should be pinned but anyways thanks guy's here is my version
Secondary clutch spring compressor.-pict0051__large_.jpg   Secondary clutch spring compressor.-pict0052__large_.jpg
Bubbasoffroad2 is offline
Old March 5th, 2009, 12:37 AM   #16
bustamove's Avatar
hate to bring up and old threat so from what i gather its a 2 inch diameter pipe you need to fit over the spring.
bustamove is offline
Old March 5th, 2009, 09:28 AM   #17
<div class='quotetop'>QUOTE (bustamove @ Mar 4 2009, 11:37 PM) <{POST_SNAPBACK}></div>
hate to bring up and old threat so from what i gather its a 2 inch diameter pipe you need to fit over the spring.[/b]
Yes I believe so
Old March 5th, 2009, 09:57 AM   #18
I think they are using a 2 or 2.5" cap with a cutout. Here is the dementions of my EPI compressor.
http://i483.photobucket.com/albums/rr196/B...ringcomp002.jpg
Old March 5th, 2009, 10:27 PM   #19
MetalMan's Avatar
You need a 2" steal pipe cap. A piece of 5/8 all thread and a few nuts and washers. I have a pic of the one i made listed above but I've since when back and cut another widow in it. So it has two now. This will allow you to get to both sides of the cir clip.
Heres a pic. Works great.
MetalMan is offline
Old March 7th, 2009, 01:28 AM   #20
thats awesome, I should build one when I get bored
Go Back   Brute Central Forums » Brute Forums » Articles
brute compressor rod
how to make a clutch spring compressor
how to make a secondary spring compressor
how to make clutch spring compression tool
how to make secondary clutch compression tool
how to make secondary spring removal tool
make clutch spring compressor
metalman welding
secondary clutch spring compressor
secondary spring compression tool
spring compression tool for secondary clutch
Article Tools
Similar Articles
Article Author Forum Replies Last Post
Changing Secondary Clutch Spring jaup09 Brute Engine & Drivetrain 21 November 22nd, 2008 05:19 AM
Anyone have a link to a how to for secondary clutch spring? ojcool Brute Engine & Drivetrain 2 August 8th, 2008 11:19 PM
Secondary clutch spring mossy Brute Engine & Drivetrain 9 July 30th, 2008 08:35 PM
Secondary clutch spring compressor tool Aussiebrute Brute Engine & Drivetrain 6 April 26th, 2008 12:09 PM
Secondary clutch spring compressor. shawn3806 Brute Engine & Drivetrain 0 December 31st, 1969 08:00 PM
