Forum Members: 4,741
Total Threads: 5,997
Old August 2nd, 2010, 09:56 PM   #1
Default Help
I have 07 650 straight axle I recently bought. I have put new valves , cleaned carbs , it cranks good but will only run when it's on choke .One of my buddies thinks it's a fuel issue, I am thinking low compression, it's the back carb that not hitting , haven't sone compression test yet. This is my 1st brute force, not my first 4 wheeler. Any suggestions would be appreciated.
Scott72 is offline
Old August 2nd, 2010, 10:56 PM   #2
Check the compression but check the valve setting to be sure they are correct. If you will also drain the carb bowls into something you can measure the amount of fuel and see if there is any water in the bottom. Pull the fuel line off the carbs and crank it...see that it has a good solid stream. If not, look to the pump or crap on the intake screen in the tank. The other thing these are sure to do at some time is crack carb boots. The clamps cut the boots and you then suck air. enough air and it will need the choke to run.
Old August 3rd, 2010, 11:40 PM   #3
Thank you , I haven't done a compression test yet, I had a chance today to get proper valve settings . I also noticed my pilot jet wasn't real clean so I going to go buy 2 new ones tomorrow . You have been alot of help. Any suggestions on pilot jet & main jets I should be running . Once again thank you for your help & I will be getting 650. running
Scott72 is offline
