Forum Members: 4,741
Total Threads: 5,997
May 2nd, 2010, 03:53 PM
HELP WANTED
Here is the thing...A friend's 2008 brute,is not in the best sgape,having a few rollovers in the battle field.....He is driving it and as soon as he leaves the bar,the brute wants to go left.The left turns are easy and the rigth ones very hard.The tires are ok,same pressure,he is wearing the itp xxl 30",a-arms as he says ok so what can it be wrong?The front diff is not locked,wheels turn ok...
Any solutions?
May 2nd, 2010, 04:20 PM
Any solutions?
Have him take it to a shop and check the alignment. You can't set anything but the toe-in, but rolling it over can change caster and camber. Look at it straight on and see if the wheels look straight up and down. If one looks leaned in at the bottom, that's the side its probably turning easy toward. Bent stuff my friend...or real bad ball joints. Also check that the brakes are not hanging up on one side. Jack it up and see if both sides spin free. That's a good test for wheel bearings too.
May 3rd, 2010, 02:12 AM
i would highly recommend a alignment shop... but for the quick and dirty way. mark a spot on the tire center lug on each tire. measure the distance between the two marks on the tires AT!! axle hight off the ground.. roll the quad back or forward and let the tires turn 180 degrees, so the marks are at the back and are at axle hight again and measure and that will give you your toe in or out for a quick check.
May 3rd, 2010, 04:09 AM
Is there a way to adjust camber and caster?
May 3rd, 2010, 09:00 AM
No..except for bending the frame or a-frames. They were not made adjustable like cars are. If they are off, it means it has bent frame or a-arms.....or realy bad ball joints...or wheel bearings...or a-arm bushings.
May 3rd, 2010, 07:20 PM
Or...take the bike and throw it away lol!!!Anyway,we disassembled the front part and we could not see anything wrong....maby the left axle seems to be a little "plastic" on its movement,not so elastic if you know what i mean,inside the cv boot where the bearings are but you think that can cause such a problem?
May 3rd, 2010, 07:39 PM
A bad wheel bearing? Sure!
May 8th, 2010, 05:48 PM
Problem Fixed!Seems that tha inner side of the itps mudlite xxl they are wearing was a little worn out and because of this the bike wanted to go to the left.They changed sides,the in went out and vice versa and everything is ok...Who would imagine it....Tomorrow morning we will hit the trails and i cannot wait...it's been a while....
toe in on a 2008 brute
