Forum Members: 4,741
April 27th, 2010, 12:46 PM
Noise from front end?
On a 650i Brute :
When you cut the bike off, it makes this sound. Like my Grizzly does when you cut difflock on/off.
I happens twice I think. Everytime you cut the bike off. I think it is normal.
I noticed the other day that it does it sometimes while you are riding it. It felt like it darted slightly when it made the noise?
What is that sound?
Is it normal?
Thanks,
Adrian
April 27th, 2010, 01:11 PM
what do you mean cut the bike off?
April 27th, 2010, 01:12 PM
when you stop the bike and cut the key off.
April 27th, 2010, 01:14 PM
does it kindof sounds like when you take your hands and twist balloons together? like a squeaking sound or more of a clunk?
April 27th, 2010, 01:30 PM
Maybe... It sounds like a small electric motor. It is more of a slight grind or whine sound. I think of nails on a chalk board when I think of rubbing balloons together. It isn't like that.
April 27th, 2010, 01:57 PM
Its just your engine break actuator setting itself in the "Parked" position. They all do it. Watch at the end of this video.
http://www.vholdr.com/node/82976
April 27th, 2010, 03:43 PM
That is what I am hearing when I cut the bike off.
Thanks!!
Why am I hearing a similar sound when I am riding at low speeds?
Somebody told me it could be the belt actuator? The bikes seems to have a slight dart to it when it happens, and it usually happens when turning.
April 27th, 2010, 06:03 PM
Thanks!!
Well, at about 3mph, that actuator rotates the fork in to hold the spider/shieve against the belt for engine breaking and when you get under 3, it releases. If yours is quiet enough, you can hear it. Now if..the shieve isn't fully against the belt when it engages, it might get a little traction and feel a little like its jumping forward...although as you see in the video, it doesn't take much to move the shieve in to touch the belt. You might have something out of adjustment just a little. The actuator isn't supposed to have to actualy push against the primary spring, just hold it from coming back until below 3mph.
My advice...try not to ride much under 5mph unless you are coming to a stop. Besides...its a BRUTE, it needs SPEED...hehe
April 28th, 2010, 02:00 AM
i seconded that advice
April 29th, 2010, 03:58 PM
you guys should hear the wine mine makes when i shut the quad off when its about -30 out! sounds like a cat dying in a culvert
