Brute Central Forums » Brute Forums » Brute Talk » oil leak problem?!
Old April 1st, 2010, 11:24 PM   #21
Originally Posted by bustamove View Post
for brute long life... keep that oil topped up always.
Bustamove is right. Only about 3% of your oil is being used for lubrication at any given time. The other 97% is used for cooling. This is true with any engine. And the Brute needs all the cooling help it can get so don't let it run low. Consider an oil cooler too. Best thing I ever did for mine.
Old April 2nd, 2010, 10:12 AM   #22
Originally Posted by Eschete View Post
Sounds pretty easy I will ge on it wen I get the part bc my bike leaks to much oil right now to ride. I took it out ride Monday maybe for an hour and went sit it up and I just checked it and I am alittle above the low line. I dnt wannt mess up more than what I have to right now
just make sure when you check it that you srew it all the way in first some people just pop it in or out and not screw it in all the way and think they are low then over fill it. the brutes get overfilled they like to blow the excess out easily esp if your doind wheelies
Old April 2nd, 2010, 10:55 AM   #23
That'd for sure...and it even says in the book to screw the dipstick all the way in ro check it. Those threads are like 3/4" long...and that makes for a way overfilled engine.
Old April 4th, 2010, 04:31 PM   #24
Eschete's Avatar
sounds like a plan i will look into it so about how much did the job cost to put an oil cooler?
Eschete
2009 kawasaki brute force 650i black
2" highlifter kit
29.5" outlaws (skinnys)
itp 212 ss rims
hmf exhaust
hmf basic jet kit
full snorkel
radiator relocator
tinted out taillight
moose programer chip
Eschete is offline
Old April 4th, 2010, 04:48 PM   #25
Less then 150. I would do the 4-pass cooler If I was to do it again, and if your radiator is on top, then for sure put it under the plastics in front. Here is a link to my writeup.
How To: Engine Oil Cooler For the Brute
Eschete (April 4th, 2010)
Old April 4th, 2010, 05:23 PM   #26
Eschete's Avatar
looks like it would be pretty easy to get on ther. so would the oil cooler to the same thing as the radiator and cake up with mud just like the radaitor and over heat
Eschete
2" highlifter kit
itp 212 ss rims
hmf exhaust
hmf basic jet kit
full snorkel
radiator relocator
Eschete is offline
Old April 4th, 2010, 05:57 PM   #27
Probably...so nothing says you can't mount it in front of the radiator on top!
Old April 4th, 2010, 10:13 PM   #28
Eschete's Avatar
True that but I am kinda running out of room on the front racks and I need to put speakers up ther
Eschete
2" highlifter kit
itp 212 ss rims
hmf exhaust
hmf basic jet kit
full snorkel
radiator relocator
Eschete is offline
Old April 4th, 2010, 10:17 PM   #29
Well put it under the plastics. At worst it will still radiate some but not all of the oil's heat. At best, it will work fine.
Old April 5th, 2010, 09:18 PM   #30
Eschete's Avatar
ok i got my oil seal in come to find out 92049 was the wrong part its to small so i went back and looked come to find out its 92049A so i will wait for it to come in. but i have to say the axle was very easy to take off by hand
Eschete
2" highlifter kit
itp 212 ss rims
hmf exhaust
hmf basic jet kit
full snorkel
radiator relocator
Eschete is offline
08 brute force 750 oil catch can
2005 kawasaki brute force 750 leaking oil
2010 brute force oil return tube
650i oil leak
brute force 650 leaking oil
brute force 650 oil leak
brute force 650i oil leak
brute force 650i oil leaking from return tube
brute force bearing problem
brute force leaks oil
brute force oil leak
brute force out put shaft leaking
brute force overfull oil
can i ride my kawasaki 750 brute force with the main oil seal leaking
how bad should rear main seal leak before fixing kawasaki brute force
kawasaki brute 750 leaks
kawasaki brute force oil over fill
kawasaki brute force rear shaft leak
mounting oil cooler for brute force on rack
oil leaking from kawasaki brute force
