Brute Central Forums » Brute Forums » Brute Talk » oil leak problem?!
Old March 30th, 2010, 10:51 PM   #11
Originally Posted by Eschete View Post
I will look more into it. Ok so does anyone have the name of the part I need to get to stop the oil leak. Because I talked to a guy at a local dealership today and they dnt sell Kawasakis so he dnt kno to much about them but he said he can order the parts. If it's the part he found it only like $15 so that's good I just hope it not hell to change it out
92049... 9 bucks at Babbitts
Old March 31st, 2010, 12:21 AM   #12
Eschete's Avatar
alright i went to babbits and looked at the diagram should i get all the parts for that area r just the oil seal? that should be the only thing that went out right?
Eschete
2009 kawasaki brute force 650i black
2" highlifter kit
29.5" outlaws (skinnys)
itp 212 ss rims
hmf exhaust
hmf basic jet kit
full snorkel
radiator relocator
tinted out taillight
moose programer chip
Eschete is offline
Old March 31st, 2010, 12:45 AM   #13
bustamove's Avatar
Originally Posted by BrianMc View Post
I put a temp gauge in mine. I dont even look at it. just a conversation peice
i watch mine like a hawk. doing about 45min of straght uphill with 2 people, 20liter of extra gas, chain saw. and bunch of other goodies in the box. i climb about 5600 feet in that time.
bustamove is offline
Old March 31st, 2010, 01:43 AM   #14
Just the seal....if that's where your oil leak is.
Old March 31st, 2010, 12:52 PM   #15
Eschete's Avatar
Ight sounds good I mite order a few. Thank yall very much
Eschete
2" highlifter kit
itp 212 ss rims
hmf exhaust
hmf basic jet kit
full snorkel
radiator relocator
Eschete is offline
Old March 31st, 2010, 02:49 PM   #16
pull your chip out and see if that is the problem it could be caused by that or you could have a bad carb boot I think its to early for that usually they dry up and crack. Also you are snorkled you may have an air leak somewhere that you dont know about double check everything and if your dealer is worth its salt it doesnt matter what you did to your bike mines was heavily modified and never had a problem getting stuff fixed if your dealer is good dont worry about it. Kawi themselfs will never know what has been done they dont go and check they go by what the dealer tells them
Old April 1st, 2010, 01:31 AM   #17
Eschete's Avatar
Ok I ordered them from another website bc babbits would have takin like 2 weeks and it was crazy about shoping and handling. Ok and about removing the chip. I know wats the problem....I take my bike in places wer u can lose a bike the lift and 29.5 outlaws just helped me break the seal. Everything done to it gave me more power and less top end. And in the mud to much tourque always breaks something. So I kno for a fact now wer it's coming from. And on a scale 1-10 how hard is it to change this?
Eschete
2" highlifter kit
itp 212 ss rims
hmf exhaust
hmf basic jet kit
full snorkel
radiator relocator
Eschete is offline
Old April 1st, 2010, 09:37 AM   #18
About a 3. Do this when changing oil because when full, it will pour out when the seal is removed. Jack up the back end, pull the driveline, with a screw gun, just start a sheetmetel screw in the seal body just up from the rubber, then pry out with a screwdriver. Clean case and shaft. NO abrasives!!! Steel wool the shaft if you see a ring on the shaft. Pack silicone grease inside the seal between the guard and wipe, put a little RTV on the outer edge and install with a deep scocket that fits the outer edge. Position leven with case all the way around. Reinstall driveline...finish changing oil and filter.
Old April 1st, 2010, 08:03 PM   #19
Eschete's Avatar
Sounds pretty easy I will ge on it wen I get the part bc my bike leaks to much oil right now to ride. I took it out ride Monday maybe for an hour and went sit it up and I just checked it and I am alittle above the low line. I dnt wannt mess up more than what I have to right now
Eschete
2" highlifter kit
itp 212 ss rims
hmf exhaust
hmf basic jet kit
full snorkel
radiator relocator
Eschete is offline
Old April 1st, 2010, 10:28 PM   #20
bustamove's Avatar
for brute long life... keep that oil topped up always.
08 brute force 750 oil catch can
2005 kawasaki brute force 750 leaking oil
2010 brute force oil return tube
650i oil leak
brute force 650 leaking oil
brute force 650 oil leak
brute force 650i oil leak
brute force 650i oil leaking from return tube
brute force bearing problem
brute force leaks oil
brute force oil leak
brute force out put shaft leaking
brute force overfull oil
can i ride my kawasaki 750 brute force with the main oil seal leaking
how bad should rear main seal leak before fixing kawasaki brute force
kawasaki brute 750 leaks
kawasaki brute force oil over fill
kawasaki brute force rear shaft leak
mounting oil cooler for brute force on rack
oil leaking from kawasaki brute force
