Brute Central Forums » Brute Forums » Brute Talk » Fuel pumps burining up.
Old April 1st, 2010, 02:22 AM   #11
bustamove's Avatar
the frame acts as the line... i was cleaning mine one day i pulled this little tube out of the frame... i was like OH YEAH!!!! this will not due. and i don't usually ride in mud... should have routed it upto the pod like everything eles.
bustamove is offline
Old April 1st, 2010, 09:50 AM   #12
????..I thought the line just ran all the way through the frame to come out the front, then up to the pod....it doesn't??? Just stubbed in there??
Old April 1st, 2010, 04:01 PM   #13
SWBF900's Avatar
Your right, it is suppose to be running through the frame then up to the Pod.
EAGLE EYE HID's
VHOLDR 1080P Helmet Cam
Ramsey 2500# Wireless Winch
Ricochet Belly Plates
CHUCK750 HDPE footwell Skids
API a/arm Guards
Powermadd Handguards
EHS Mudder Lid
UNI Air Filter
PBR Diff Lock Button
AMStar MX-Pro Tie Rods/Ends
Trail Tech Voyager GPS unit
SWBF900 is online now
Old April 1st, 2010, 04:33 PM   #14
I thought so. I gave mine a tug on either end it seems to go through. That's why I don't understand why people are re-routing that outside the frame to the pod...when it already goes to the pod and its protected by the frame. Is it just me..or am I missing something.
Old April 1st, 2010, 11:36 PM   #15
SWBF900's Avatar
Unless it is disconnected at the exit on the front of the Frame(shifter), then yes, you can have a problem.
EAGLE EYE HID's
API a/arm Guards
EHS Mudder Lid
UNI Air Filter
Old April 25th, 2010, 07:56 PM   #16
I finally put the new pump on today, hooked everything back together and tried to start it. Its not getting gas. The pump is working fine when we disconnect the hose its got pressured gas in it. The guy thats helpin me work on it said there is a water sensor underneath the air filter and that it couldve gone bad and thats whats resticting the gas from going in. Let me know if u know anything about this cause im really ready to ride!!!!
peedysbrute is offline
Old April 25th, 2010, 08:03 PM   #17
Never heard of such a thing. Its fuel injected. If the rails have the proper pressure to the injectors, then the injectors are not functioning. That could be a controler issue or connection issue. Also could be a crank position sensor bad.
Old April 25th, 2010, 10:11 PM   #18
I looked it up on babbits the sensor is about 38 bucks. There is an air and a water sensor under the box. If u put gas in it manually it runs so its got to be some sensor.
Old April 26th, 2010, 01:08 AM   #19
Hmm...Okay. So....just what does this thing do?
Old April 26th, 2010, 03:00 AM   #20
bustamove's Avatar
mine only goes into the frame like 1/2 then uses the frame as its tube upto the shifter then continues to the pod. but if that connection at the frame side or if the tube pops off then it will suck in mud.
http://www.bikebandit.com/houseofmot...17994sch582193
09 brute force fuel pump
brute force 750 fuel pump quick fix
brute force fuel pump connector burnt
ehs mudder cover pics
