Old March 2nd, 2010, 11:32 AM   #11
If it were my Brute, I'd stay stock. Reason being is I've had my fill of buying all those aftermarket hop-up parts, constantly tinkering with the machine, and all that with that ZX-7 roadrace bike I mentioned earlier. The only modifications I've done to my '07 Brute is a Moose Module, Warn XT30 winch, Warn ProVantage plow, 26" Swamplites on black ITP SS-108 wheels. It does everything I want it too and I don't have to constantly tinker with it to keep it running.
2007 Brute 750i
Warn XT-30 Winch
Fender Flares
richracer1 is offline
Old March 2nd, 2010, 01:43 PM   #12
bruteboy's Avatar
what kind of tinkerin do you have to do?
bruteboy is offline
Old March 2nd, 2010, 01:46 PM   #13
If it were me, I would run with a stock crank and rods, but install aftermarket high compression pistons and some aftermarket cams. Your going to have to "tinker" with the jetting after if its carb'd or buy a fuel controler to dial that in properly, but your going to have one hell of a power increase.
get r dun!!!
Old March 2nd, 2010, 04:04 PM   #14
bruteboy's Avatar
do you have any request on the pistions an cam and a website i could get them?
bruteboy is offline
Old March 2nd, 2010, 10:54 PM   #15
www.fourstroketech.net
www.fundyperformance.com
thoes are two pretty good companys that specialize in the kawie twin
07 brute force 750 rod and bearings
07 brute force 750 rod knockinh
4 cylinder toyota crank bearings in a brute force
750 brute force motor knock
brute force 750 crank bearing
brute force 750 crankshaft needle bearing
brute force 750 engine knocking
brute force 750 engine rapping
brute force 750 knocking
brute force 750 rod knocking
brute force 750 spun bearing
brute force engine knocking
brute force knocking
how much to fix engine knock brute force
how to tell if rod bearing is bad on brute force 750
knocking in brute force 750 motor
kvf 750 spun rod bearings
pistons and rings in brute force damage cylinders
rod bearing 750 brute force aftermarket
sportsman 700 right cylinder knocking
