Brute Central Forums » Brute Forums » Brute Talk » does 28s need new axles
Old February 25th, 2010, 11:02 PM   #1
bruteboy's Avatar
Default does 28s need new axles
if i put 28s on my bf750 will i need to put axles or will it be fine if i run it in low when in the mud? and will the 28s rub any? thanks
bruteboy is offline
Old February 26th, 2010, 12:28 AM   #2
Some 28s do rub but some don't. Probably a 2" lift would be in order. Stock axles work in lost normal situations. If you find you are breaking axles, then go with one of the aftermarkets.
Old February 26th, 2010, 12:54 PM   #3
bruteboy's Avatar
i dont wont to spend too much on axels but is there any diffrent axels besides gorilla?
bruteboy is offline
Old February 26th, 2010, 02:59 PM   #4
DPS
DPS's Avatar
dont know about needing axles, I run 28's on my 06 BF750 but my wheels are offset and i have no issues other than staying clean on muddy trails..I have HL springs on the bottom notch.. An help me out here NMKAWIERIDER.. The springs dont lift the bike..Do they? they were on it when i got it.. I wanna do a 2" lift so I can later clear 30's
2006 Brute 750 4x4i
Gorilla axles, 28's, Full Muzzy, K&N, DJ Jet kit, Warn 2.5 Winch, Skid Plates, 2.5" snorkel
DPS is offline
Old February 26th, 2010, 03:05 PM   #5
I have been running 27" swamplites that measure almost 28 when new. Never had a problem with my stock axles! And I run them long and hard and put em up wet! I agree with NMKAWIERIDER, If you have any rubbing issues add a 2" lift kit and get after it..
Slumlord is offline
Old February 26th, 2010, 04:24 PM   #6
bruteboy's Avatar
so your saying just keep the stock belt?
bruteboy is offline
Old February 26th, 2010, 04:25 PM   #7
bruteboy's Avatar
how do you think 28" swamplights would perform?
bruteboy is offline
Old February 26th, 2010, 04:31 PM   #8
bruteboy's Avatar
with the two inch lift would you need new springs?
bruteboy is offline
Old February 26th, 2010, 04:46 PM   #9
Right, they don't lift it other then make it stuffer and handle more weight.
Old February 26th, 2010, 04:48 PM   #10
Probably could use a set of springs, but if the belt is good...keep it.
how much can you lift a brute 750 with stock axles
how much lift can u put on a brute force with stock axle
new axles for a 2 lift brute force
