Forum Members: 4,741
Old May 23rd, 2008, 12:24 AM   #1
Default 08 snorkel
Can you use mudinmyblood instruc. for 08 brute snorkel? If so, is everything the same or is there changes to be made?
ghostof1777 is offline
Old May 23rd, 2008, 04:43 PM   #2
csw1510's Avatar
Default 08 snorkel
I would imagine that it's very simular. It was a little different for my 650i, but it got me going in the right direction. I would use it as a guideline and work the rest out.
Cheers
Chris
'06 650i BF with a few goodies to help me play.
http://gi107.photobucket.com/groups/...12-09002-1.jpg
csw1510 is offline
Old May 28th, 2008, 12:35 AM   #3
KevinB427's Avatar
Default 08 snorkel
It's the same, Ive done 5 08 750s with the snorkel I came up with wich is pretty much the same as mudinmybloods butt a little diferent.
I just traded my 06 750 for a 08 750 and am trying somthing a little diferent on my bike for the airbox intake, it ought to flow alot better.
09 KTM 250xcf, 08 BF 750i Snow camo, 00 450ES, IRS, made by me, 8" lift, pic's below.
http://good-times.webshots.com/album/558529966BZaWud
"I think you can make it"
KevinB427 is offline
Old May 28th, 2008, 09:13 AM   #4
Default 08 snorkel
Works just fine. Just be sure to use a 3" rubber 90 degree elbow with the ends cut off for where the air intake snorkel attaches to the the airbox. Also, It's a good idea to run a piece of hose down from the airbox (in place of the duck bill) with a valve on the end of it. That way if you get any water in the airbox it will fill that hose instead of sitting in the airbox and you can drain it by just turning the valve open. Also remember to run the gas tank vent line up to the pod and use dialectric grease on plug wire boots and all electrical connections and fuses.
Waterfreak66 is offline
snorkel&jet kit=top end lag? DruNk Brute Snorkeling 5 May 22nd, 2009 12:27 AM
To snorkel or not to snorkel.. Lupine750 Brute Snorkeling 25 February 24th, 2009 11:44 AM
What is the third snorkel for? machinewars Brute Snorkeling 2 March 20th, 2007 12:21 AM
snorkel bruteguy1 Brute Snorkeling 4 March 15th, 2007 11:00 PM
snorkel? gixxer1000 Brute Snorkeling 3 January 15th, 2007 01:24 AM
