Forum Members: 4,741
April 7th, 2008, 02:08 AM
Vent lines
Hey everyone, I am new to this site as I just bought an 08 750i camo, what A blast to ride. My question was about all the vent lines, are they already up in the pod or do they need re-routed???? Diffs/gas tank and???
Thanks
CB
08 Brute 750i Camo
Warn 2.5 RT
Full aluminum skids
Powermadd hand guards
27x10-12 & 27x12-12 Swamplites
April 9th, 2008, 06:04 AM
Vent lines
I think they all go to the pod, there is a bunch of them up there
07 Brute Force 750i
Muzzy Full Exhaust, Dynatek CDI,
26" Swampfox Plus, EPI Maroon primary
3500 lb winch, Aluminium skids, Snorkles
HID conversion
April 12th, 2008, 08:44 PM
Vent lines
Most of your vents are already up there but its a good idea to go ahead and run the gas tank vent up. It has a checkvalve that is run to the frame but thats it. I went a head and ran mine all the way up to the pod. Its very easy to do. I also ran my crankcase vent up to the pod as well. The crank case vent is attached to the bottom of your air box. If you do long wheelies it will cause oil to enter the air box through the vent line and enter the pistons causing your bike to briefly smoke.You do not have to move this vent but it will keep you from smoke with long wheelies and also help prevent water from entering the bottom half of the motor in the case you do get water in the air box.
08 750 FI Brute Force Team Green
VFJ Stage 3 Spider Mod
VDI CopperHead
HMF Swamp Series XL
Snorkels with 2 1/2 air intake (mudinmyblood.com)
28" Zillas ITP SS 112's
6K H.I.D Head Lights
April 20th, 2008, 11:20 AM
Vent lines
What about the coolent overflow tube, and what is the one at the very bottom of motor I noticed it when I put my skids on.
08 Brute 750i Camo
Warn 2.5 RT
Full aluminum skids
April 21st, 2008, 05:02 PM
Vent lines
The gas tank vent and the crank case vent need to be run up there like mentioned earlier. The one you noticed when putting on your skids is probably you carb bowl drains. There is a check valve on them, so it shouldn't be an issue. Some people take it out and just run a piece of the tube from one drain to the other. Then they have to unhook one end to drain one bowl and then hook it back up and unhook the other end to drain the other.
April 23rd, 2008, 01:10 AM
Vent lines
The gas tank vent and the crank case vent need to be run up there like mentioned earlier. The one you noticed when putting on your skids is probably you carb bowl drains. There is a check valve on them, so it shouldn't be an issue. Some people take it out and just run a piece of the tube from one drain to the other. Then they have to unhook one end to drain one bowl and then hook it back up and unhook the other end to drain the other.[/b][/b]
The bottom tube is coming out of the bottom of the engine under where the coolant goes in. Coolant impellar area??? I ran it up to the pod along with the coolant tank overflow tube, just to be safe.
CB
08 Brute 750i Camo
Warn 2.5 RT
Full aluminum skids
brute vent line under engine, vent lines ran to the pod 2009 brute force 750, what are the four vent lines that go to the top of the pod in my 2009 brute force 750
