Brute Central Forums » Brute Forums » Brute Snorkeling » 2008 750 fuel injection snorkel
Old March 7th, 2008, 09:14 PM   #1
Default 2008 750 fuel injection snorkel
does anyone know if you need to do anything speical....with the carb i here about jets kit ect. ?
thanks
brunswick69 is offline
Old March 8th, 2008, 12:29 PM   #2
any help?
Old March 8th, 2008, 12:44 PM   #3
you do not have to do anything with fuel injection. thats what my dealer told me
manitoba brute is offline
Old March 8th, 2008, 02:05 PM   #4
thats the beauty of efi you don,t have to do anything for the fuel/air mixture the computer will self adjust, just make sure use 2in intake and you,ll be fine
05 750,2in lift, snorlkles,hmf,cdi,28 swamplites,snorkled exhaust
brutster is offline
Old March 8th, 2008, 04:38 PM   #5
thats the beauty of efi you don,t have to do anything for the fuel/air mixture the computer will self adjust, just make sure use 2in intake and you,ll be fine [/b][/b]
Not to bust your chops, but for the benefit of everyone who might read this, the information you provided is WRONG. The injected brutes do NOT have a mass air sensor, nor do they have an oxygen sensor. The "computer" if you will, in the brute has NO means whatsoever of adjusting the air/fuel mixture to account for snorkels or various other add ons. If you dealer told you it would, he lied, if your buddy told you it would, he lied. You will need to purchase a programmer to change the fuel/air ratio of your injected brute.
06 BF 650i camo, 3000lb Winch, Kolpin Fuel Cell, EPI Maroon Primary, K&N Airfilter, Outerwears Prefilter,Dynatek CDI, 27" Mudlite XL on 14" Type 7 ITP Black Rims, Custom Shift Knob, .38 S&W JIC
Newbruterider is offline
Old March 8th, 2008, 05:25 PM   #6
thanks ......what is involved with that?
Old March 8th, 2008, 10:47 PM   #7
Brute Man Kelley's Avatar
I snorked my buddy's 08 EFI, center in front of handle bars and removed the mesh screen under the air filter and it really improved his performance. I used 2" abs pipe.
BF 785 Highly modded
CWR MACH 3 CAMS
68.28 RWHP ON MOTOR
NOS EQUIPPED IF NEEDED
4.7 300ft. on motor 4.3 300ft. on NOS
Head work (valves, porting,etc.) BBK Kits
Complete Engine Work
BMK Performance* (PM for more info)
MUZZY DEALER
704 637-1207
Brute Man Kelley is offline
Old March 8th, 2008, 11:16 PM   #8
Not to bust your chops, but for the benefit of everyone who might read this, the information you provided is WRONG. The injected brutes do NOT have a mass air sensor, nor do they have an oxygen sensor. The "computer" if you will, in the brute has NO means whatsoever of adjusting the air/fuel mixture to account for snorkels or various other add ons. If you dealer told you it would, he lied, if your buddy told you it would, he lied. You will need to purchase a programmer to change the fuel/air ratio of your injected brute.[/b][/b]
Ops me bad, I was given bad info sorry for passing it on
brutster is offline
Old March 9th, 2008, 08:35 PM   #9
Kakshrub's Avatar
I am about to snorkel my bf 750 08 and I was wondering how much the programmer is that I will need?Do you need this programmer 100% or just if it isnt running good after you finish? This stuff is starting to get expensive..lol
Team Green 2008 Brute Force 750
27'' Mudlite xtr w/14'' ss112
Garmin Gps
Muzzy Exhaust, Power Commander
Kakshrub is offline
Old March 9th, 2008, 10:12 PM   #10
That depends.. When you snorkel the brute, you're going to reduce the amount of air that is coming into the carbs. Generally, most bikes come lean from the factory to deal with EPA B.S. You MIGHT not need the programmer, but then again you might. As BMK said, removing the screen does allow for more air to flow to the carbs as it is rather restrictive. This may work in your case, it may not. All the programmer is going to do is allow you to add or reduce the amount of fuel going into the carbs. It's a trial and error thing. Not too sure on the prices of programmers as I'm still running a carbed 06. But from what I hear they're not cheap
2011 brute self adjust for snorkels
brute force 750i snorkel
brute force dynatek fuel injection review
do i need a power commander for a brute force if i snorkell it
do i need a powercomander for my 2008 brute force 750i if i snorkel it
how to snorkel a brute force 750
how to snorkel brute force 750 2008
is a 2006 brute force fuel injected
is a 2008 brute 750 fuel injected
power commander programmer 2008 brute force
snorkeling a 2008 fuel injected brute force
snorkeling brute force fuel injection
when did brute force 750 go to fuel injection
when did brute force get fuel injection
programmer for fuel injection brunswick69 Brute Engine & Drivetrain 0 March 8th, 2008 05:49 PM
2008 brute force is fuel injected sdteb Brute Talk 1 June 20th, 2007 02:11 AM
