Old March 26th, 2007, 09:36 PM   #1
bf750's Avatar
Default Snorkel Question (help)
I installed a bayou snorkel. Went for a ride and everything was well. Ran good. Now I load up on the trailer and drove two and half hours to go riding. When I went to unload the machine didn't want to turn over. I thought maybe the starter, but when I went to pull the pull rope it didn't move. It was like the piston was seized. Well after about a long minute of pressing the starter button a bunch of times it finally turned over. Then it took a minute to get it started. I was wondering if anyone has had the same problem? It did the same thing when I got home that evening. It took a minute for it to unseize and then another minute for it to start. Any info or advice would be great. I am going to Coalcreekohv with killzoneq2 in May and I don't want to have any problems.
05 Camo bf750
Moose cdi kit
Ricochet* Full Skids
A set of stock size dirt devils for trail riding and 26in Titan MTs for mudding.
Full set of Works Shocks
bf750 is offline
Old March 26th, 2007, 09:49 PM   #2
I had the same issue and posted a similar question. You need to cap the snorkels when you transport the quad. Your forcing air into the quad and flooded the engine.
Take a look at this link for a more detailed explaination.
http://www.brutecentral.com/forum/index.ph...ic=1575&hl=
07 BF 650i
machinewars is offline
Old March 26th, 2007, 10:41 PM   #3
bf750's Avatar
Thanks Machinewars that will help.
05 Camo bf750
Moose cdi kit
bf750 is offline
Old March 27th, 2007, 11:12 PM   #4
The air coming into the snorkels while traveling forces fuel into the cylinders therefore making them vapor or liquid locking and you need to change your engine oil because you now have gas in the engine oil. NOTE: if it does this again do not keep trying to start the engine remove the spark plugs and then turn the engine overto get the gas out of the cylinder if you continue to try to start the engine you will take a chance on bending a connecting rod and then you will have to tear down and replace the connecting rods inside the engine.
Jason McGlawn is offline
Old March 28th, 2007, 10:38 PM   #5
bf750's Avatar
Thanks Jason I sure don't want to have to do any extra work on the brute at this point in time.
05 Camo bf750
Moose cdi kit
bf750 is offline
Old March 29th, 2007, 01:44 PM   #6
I have heard of that happening but I have not had a problem with it.
2006 Brute Force 650SRA--SOLD!!--2007 Arctic Cat 650H1
Warn 2500# Winch
28" Mudzilla's on ITP Delta's,HLP Lift kit, HLP Springs,Snorkels,
Moose Module
http://community.webshots.com/user/LAMUDBRUTE
LA MUDBRUTE is offline
Old March 30th, 2007, 12:31 AM   #7
Not everyone has the problem but i have about eight different customers that have the brute and two of them have had that problem but they had me extend the snorkel tubes up a little higher than the rest so the only thing i can figure is the heigth on the tubes have something to do with it. It also varies if they tow them on a trailer or in the truck if they are on the trailer they tend to catch all the air coming over the truck and if in the truck they dont catch as much because the cab blocks most of the air. That is the only thing i can think of though.
2005 Brute 650 SRA Snorkel Question maclove73 Brute Snorkeling 1 May 10th, 2008 01:00 PM
snorkel question bctoasters Brute Snorkeling 2 December 26th, 2007 02:39 AM
Another snorkel question montean Brute Snorkeling 1 April 20th, 2007 09:52 PM
Snorkel Question montean Brute Snorkeling 8 April 19th, 2007 09:41 PM
Snorkel Install Question? machinewars Brute Snorkeling 4 March 19th, 2007 10:52 PM
