Brute Central Forums » Brute Forums » Brute Snorkeling » Need help after installing EHS mud lid.
Old May 28th, 2009, 12:37 AM   #1
swabber30's Avatar
ok guys i need your help. i purchased a ehs mud lid and installed it and the bike didn't run good. so i bought a twin air power flow system, installed that and the bike still won't run right so this is were i need help. i took a spark plug out and it is black on the end and it was a brand new plug. i also am running a dyne tek and a pro circuit pipe. and haven't did any jetting. so if anyone has any in put in to what i should do that would be cool. also if a guy does have to rejet can any one give step by step directions in how to do it and what way a guy should jet (up or down). thanks for the help guys.
07 brute 750(black)
dynatek cdi
mud lite tires
ss112 rims
2" lift
maroon primary
belt snorkels
procircut pipe
twinair power flow kit
dyno jet kit
front and rear bumpers
storage pod
swabber30 is offline
Old May 28th, 2009, 11:03 AM   #2
what year is your quad and size more then likely your lean from the pipe
Old May 28th, 2009, 08:30 PM   #3
swabber30's Avatar
<div class='quotetop'>QUOTE (VTprairie @ May 28 2009, 02:03 PM) <{POST_SNAPBACK}></div>
what year is your quad and size more then likely your lean from the pipe[/b]
my quad is a 07 750 brute. it runs alright at an idle and till it hits mid range then it falls flat on its face. after taking for a ride i pulled a plug and it was black like sut on it. so i don't know if that helps the diagnosis.
07 brute 750(black)
dynatek cdi
mud lite tires
ss112 rims
2" lift
maroon primary
belt snorkels
procircut pipe
dyno jet kit
storage pod
Old May 28th, 2009, 08:47 PM   #4
from the sounds of that it sounds rich but if you ran good before the lid and powerflo kit it doesn't make sense that you are having issues with them installed. The mud lid seems to let less air in but is countered by the powerflo kit because it takes air from the top. Next question did you block the front intake.
Old May 28th, 2009, 09:02 PM   #5
dbltyme31's Avatar
If you don't get any satisfaction here try calling the guys at EHS @ 1-866-997-2345. I purchased a few things from them for my '09 which of course is FI but these guys really know their stuff down there and I'd be willing to bet they could fix you right up.
dbltyme31 is offline
Old May 28th, 2009, 09:22 PM   #6
<div class='quotetop'>QUOTE (VTprairie @ May 28 2009, 05:47 PM) <{POST_SNAPBACK}></div>
from the sounds of that it sounds rich but if you ran good before the lid and powerflo kit it doesn't make sense that you are having issues with them installed. The mud lid seems to let less air in but is countered by the powerflo kit because it takes air from the top. Next question did you block the front intake.[/b]
I'm with VT on this one. The lid did require you to block the stock intake and if you did not, you are very lean. But if you did, take something like a cigarett butt and lay it across the lid seal by one clip and clip the other leaving the one unclipped. Run it down the road and back. If it runs better, then its just not getting enough air for some reason. Check the install on the lid parts and the prefilter. But if worse, then its even leaner . It's up to you to find out why. One thing I had was a split carb boot sucking air in and making that cylinder very lean. Couldn't see it. Had the carbs off a dozen times looking for the reason then finaly checked the boots.
Old May 29th, 2009, 12:06 AM   #7
swabber30...Black sot on your plugs generally means you're running too rich (getting too much fuel for the amount of air it's getting) Two fixes, find a way to get more air would be the best. By getting more air you will also get more power. Your other option is to jet down, in other words feed the engine less fuel in which case you could end up with a little less power.
I would recommend that you check to make sure your choke plungers are not getting stuck open because this will also cause you to run rich.
It's unlikely that your carb boots are torn because if they are, you would be running a lean condition and your plugs would be light in color and without sot.
Hope this helps.
moneypit is offline
Old May 29th, 2009, 03:06 AM   #8
Forgot about the choke plungers. That is a common problem along with the cables and springs haveing problems.
Old June 10th, 2009, 08:22 PM   #9
wvMOUNTAINMAN's Avatar
you are way rich!!!! just my 2 cents but that lid would be coming off I'd bet it would run better with mimb snorkels, its half the price and alot safer for the motor, from what I've read these lids do alot better on the efi brutes
wvMOUNTAINMAN is offline
Installing Inner Tire Rod End Thom Brute Chassis & Electrical 8 November 3rd, 2008 10:55 AM
When installing snorkel zilla500abrute750 Brute Snorkeling 4 May 1st, 2008 10:55 AM
Installing 26 Dirt Devil II's Toyaholic Brute Tire & Wheel Combos 1 March 24th, 2008 11:11 PM
Installing Skid Plates tayloraa007 Brute Chassis & Electrical 3 November 9th, 2007 03:51 PM
Installing HMF Slip-On Giese86 Brute Engine & Drivetrain 1 November 4th, 2007 06:01 PM
