May 14th, 2009, 08:07 PM
ok guys i spent the money and put a EHS mud lid on and my bike ran like shit. So i was wondering if anyone else put this on and had to re jet and if you did what size of jets. i am running a 07 brute 750 with a dyna and k/n filter. if you guys have any input then let me know. thanks
07 brute 750(black)
dynatek cdi
mud lite tires
ss112 rims
2" lift
maroon primary
belt snorkels
procircut pipe
twinair power flow kit
dyno jet kit
front and rear bumpers
storage pod
May 14th, 2009, 08:39 PM
<div class='quotetop'>QUOTE (swabber30 @ May 14 2009, 05:07 PM) <{POST_SNAPBACK}></div>
ok guys i spent the money and put a EHS mud lid on and my bike ran like shit. So i was wondering if anyone else put this on and had to re jet and if you did what size of jets. i am running a 07 brute 750 with a dyna and k/n filter. if you guys have any input then let me know. thanks[/b]
Talk with Slumlord. The K&N and the stock filters is too close to the top to allow enough air to pass by. Slumlord fix it by going with the TwinAir system which gets it air all the way around including the top. Sorry man, no way around it.
May 14th, 2009, 09:14 PM
Yes, its a lack of air! I didn't like the thought of rejetting when it was running excellent before the mudlid! You can rejet to get it right but you will have to go smaller on the jets. Less air and less gas means less power and go to me!! You can test your brute to see what I am talking about by popping the clamps on the mud lid and stick a pencil under the back end. that raises the back of the lid and lets more air in. It will run much better. I took off my mudlid and cut a sheet of 1/4" thick rubber and started playing with the opening I cut in the rubber. I started out exactley the same size of the mudlid entrance and then started cutting bigger and bigger. Made two cuts and then it quit making a difference. And still ran better with the lid cracked open with a pencil. That told me it was not the inlet size killing me. I took the aluminum mudlid off and just put the plastic airbox cover back on so I could see what the restriction was. The filter hold down plate almost blocks off the mudlid hole. I took off the hold down plate and used a zip tie to hold the top of my filter in place and not let dirt in. It ran much better but still not back to what I had. Then I found the TwinAir Power flow kit. This is sweet, a little high but excellent product. The filter rack fits up inside the filter which breaths from all around like K & N and stock but also straight from the top. More air flow!! All power is back and some! I'll tach some pics of my test lid, my old filter zip tied which worked well enough to ride until my Powerflow kit came in. My powerflow kit and anything else you may need to see. This is a good fix but like I said, a little high... I do love the mudlid and knowing where the mud and water level is at all times. Also love the waterproof prefilter so even If I accidentally dunk it, I am protected. The bike will die due to lack of air but not drown, I poured water into my mudlid and none got through. choked it down but none got in...
[attachment=2055:151391C.jpg][attachment=2056:IMG00191.jpg]
[attachment=2057:IMG00192.jpg][attachment=2058:IMG00198.jpg]
[attachment=2059:IMG00200.jpg][attachment=2060:IMG00201.jpg]
May 22nd, 2009, 12:14 AM
Slumlord is right on the money, Twin Air is the way to go with the EHS lid!
750 brute force jetting and ehs lid, 750 brute force with ehs mud lid, brute force jetting with ehs lid, bruteforce mud lid, ehs lid 750 brute force jetting, ehs lid and jetting 750 brute force, ehs lid on brute, ehs mud lid, ehs on brute force 07 or mud lid ?, mud lid, twin air 151391c
jetting still not right
hillrod660750 |
Brute Engine & Drivetrain |
1 |
December 24th, 2007 02:21 PM |
little help with jetting
theconquistador |
0 |
December 9th, 2007 05:26 PM |
Jetting Help
Smokeshow |
2 |
May 22nd, 2007 08:33 PM |
