Old March 10th, 2009, 06:02 PM   #1
kawasaki1's Avatar
I had a friend snorkel 2 of my brutes both are 2006 4x4i one is a 650 the other 750.He has also done his and a couple of friends and they all work ok but my sputters when water is over the tires.Not only does it sputter and backfire but the red reverse light comes on once i get it out of the water the red light starts to fade away till it is gone and runs fine till i get back in the water.I do not ride through the water fast i go in and the try to pull a water wheelie.Dose anybody else have this problem or is it just the 06.My friends are 2007 thru 09.
Red 2006 750 Bruteforce,highlifter ECU,HMF Exhaust,29 1/2"Outlaws on Red Platoon rims,Kenwood stereo,2 6x9 Memphis speakers,2 4" Memphis speakers,300 watt Boss amp,speaker box and stereo box,2 Ammo boxes for storage,Ice chest and ice chest rack and snorkels.
kawasaki1 is offline
Old March 10th, 2009, 06:43 PM   #2
<div class='quotetop'>QUOTE (kawasaki1 @ Mar 10 2009, 03:02 PM) <{POST_SNAPBACK}></div>
I had a friend snorkel 2 of my brutes both are 2006 4x4i one is a 650 the other 750.He has also done his and a couple of friends and they all work ok but my sputters when water is over the tires.Not only does it sputter and backfire but the red reverse light comes on once i get it out of the water the red light starts to fade away till it is gone and runs fine till i get back in the water.I do not ride through the water fast i go in and the try to pull a water wheelie.Dose anybody else have this problem or is it just the 06.My friends are 2007 thru 09.[/b]
I have an 06 and have not had that problem yet. Sounds like water is getting in the reverse pin connector that is about that level on the block. I forget which side, but check any and all wires going to the engine/transmission block about that level. Pull off, dry well, and use dielectric grease when reinstalling.
Also, might as well check any connectors you find that could be getting under water...you never know.
Old March 10th, 2009, 09:21 PM   #3
07galaxy650's Avatar
^^^^X2. Need that grease on all wire connectors that you can get to.
07galaxy650 is offline
Old March 11th, 2009, 05:10 PM   #4
kawasaki1's Avatar
Thanks guys,i talked to a local Mechanic in Crosby and also read something on Nyroc and they said that the Sensor on the left side by the coolant canister causes this when it gets wet.This is also the reverse override they say to disconnect the Red with White stripe wire and you won't have to hit override button when you go in reverse.Also when you disconnect the wire they said to put some dielectric grease and tape up good to keep water out of it.I will do this and try it out this coming weekend and let you all know if it worked.Thanks again for your help guys.
Old March 11th, 2009, 07:53 PM   #5
Cool. Good luck
Old March 11th, 2009, 07:54 PM   #6
keep us posted
Old March 23rd, 2009, 10:14 AM   #7
kawasaki1's Avatar
Post
Went out this weekend to Crosby to see if my Brute would still sputter in deep water after disconnecting the Red and White wire to the reverse overide and Brute ran like a Champ, no more sputtering.Thanks guys for all your help this is a Bad A?? website.
2006 brute force 650 dont run when get wet
2006 brute force ecu problems
2007 kawasaki brute force 750 4x4i spitting and backfireing in reverse
2009 brute force spitting and sputtering youtube
750 brute force popin when on water
750 brute force spitting out oil
brute force exhaust under water
brute force ice chest
brute force ice chest holder
brute force ice chest rack
brute force reverse light coming on under water
brute force snorkel speaker box
brute force sputter in water
brute force sputtering when in water
brute force wet spuddering
kawasaki brute force sputters in reverse
kawieriders
my brute force spits and sputter when i hit water
speakers and box for brute force 750
what causes brute forces to spit and sputter
Little Water Fun Thom Pictures & Videos 2 July 9th, 2009 12:31 PM
spitting and sputtering lilbrute Brute Engine & Drivetrain 4 July 19th, 2008 05:51 PM
poping and sputtering fast64 General Discussion 7 June 24th, 2008 10:10 AM
Water! Sleepy General Discussion 12 October 16th, 2007 03:08 PM
sputtering brute BRICKLAYER Brute Engine & Drivetrain 3 September 20th, 2007 08:35 AM
