Old February 24th, 2009, 03:45 PM   #1
Lupine750's Avatar
All the reading I've done on snorkeling my '09 BF doesn't say anything about having to snorkel anything other than the CVT intake, exhaust, and the air intake. A friend of mine is telling me I need to snorkel the vent lines coming from the differentials as well as some line coming from the fuel injection system. I've got all the stuff to do the snorkel with (I think so anyway) and I'm wondering who is right here.
'09 Brute Force 750
Kawasaki factory front brush guard
27x10x12 Swamp Lites on black ITP SS108's
Viper Max 3000lb winch
Lupine750 is offline
Old February 24th, 2009, 03:48 PM   #2
4byrookie's Avatar
When I did mind all I did was the air intake and cvt exhaust and intake and I have been fairly deep a few times and have had no problems yet. I was told it was a good idea to do a few othe lines as well but never did.
2008 750 Brute Force, Aluminum skids, 1.5" lift,*Highlift springs, 28" Zillas on 14" SS212s & chrome skull caps, HL triple core rad in stock location, HMF Swamp Series, Power Commander III, Maroon Primary spring, Symtec 4 zone H/T warmers, Custom shift knob
4byrookie is offline
Old February 24th, 2009, 06:01 PM   #3
On mine as I am sure they still do on the 09's, the diff vents are routed up to the pod, so as long as the bars are out of water, they are too. I don't know about any vent relating to the FI system, but it could be routed up there too...I guess.
Old February 24th, 2009, 10:52 PM   #4
Lupine750's Avatar
Wow..what a tee-total pain in the backside. I started getting the stuff together this morning for the snorkels and worked on it off and on throughout the day. Should come out ok although I'm not real crazy about cutting plastic. As soon as I get it all together I'll put some pics up..It'll probably look like hammered cat-poop but as long as it gets the job done, that's all that matters I guess. Something tells me I shoulda just went with the mud intake and been done with it..
'09 Brute Force 750
Old February 24th, 2009, 11:01 PM   #5
<div class='quotetop'>QUOTE (Lupine750 @ Feb 24 2009, 07:52 PM) <{POST_SNAPBACK}></div>
Wow..what a tee-total pain in the backside. I started getting the stuff together this morning for the snorkels and worked on it off and on throughout the day. Should come out ok although I'm not real crazy about cutting plastic. As soon as I get it all together I'll put some pics up..It'll probably look like hammered cat-poop but as long as it gets the job done, that's all that matters I guess. Something tells me I shoulda just went with the mud intake and been done with it..[/b]
You're braver then I am man. Mine's an 06, and I still can't bring myself to cut any holes in my plastic...although I am thinking about a water temp guage by the shifter. Good luck....and what is that they say...measure twice and cut once? Something like that.
Old February 24th, 2009, 11:14 PM   #6
Lupine750's Avatar
Tell me about it! The only consolation here is that the shroud will cover the cut plastic and although the shroud will be cut, I'm gonna fix it up a little. A friend helped me do most of the work today and if you've never done anything like this-like me-it helps to have someone else's input. MIMB has been a big help, too.
'09 Brute Force 750
Old February 25th, 2009, 12:38 AM   #7
07galaxy650's Avatar
Take a peice of spare pcv, cut an angle on it and set it on the pod cover, see if its the right angle and so on. Once you get the right angle, trace it onto the shroud and cut it out with a dremel. The take and get some small rubber hose from lowes or whatnot, and take a small pair of scissors to cut it in half and glue,wrap it around the edges of your holes. As for what else needs to be vented, I would definately vent the gas tank, the diffs and fan is already ran, vent the radiator overflow tank, and the waterpump overflow if you have extra hose. It has a valve on it so that it doesnt allow anything in, but i wanted to make certain so i vented it. Here is a pic of the two sets i made.
http://i512.photobucket.com/albums/t330/20...pg?t=1235536562
http://i512.photobucket.com/albums/t330/20...pg?t=1235536577
http://i512.photobucket.com/albums/t330/20...pg?t=1235536601
http://i512.photobucket.com/albums/t330/20...pg?t=1235536622
And the temp gauges for BF Freak.lol
http://i512.photobucket.com/albums/t330/20...pg?t=1235536641
http://i512.photobucket.com/albums/t330/20...pg?t=1235536676
07galaxy650 is offline
Old February 25th, 2009, 12:43 AM   #8
Hey man I almost forgot about that duckbill on the airbox. BE SURE you plug that shut. There is a couple how-to's on mimb about how to install a valve onto it so that you can still drain the airbox if need be. I just plugged mine shut altogether.
Old February 25th, 2009, 02:06 AM   #9
<div class='quotetop'>QUOTE (07galaxy650 @ Feb 24 2009, 09:38 PM) <{POST_SNAPBACK}></div>
And the temp gauges for BF Freak.lol[/b]
Great pics. Thanks. Now I know what it will look like. Do you have a favorite brand of guage?
Old February 25th, 2009, 02:37 AM   #10
Well heres the thing on the gauges. I was going to buy a sweet Autometer gauge b/c they are well known for their quality, BUT, they arent waterproof. So I did a little research and came across a Sunpro by Snap on. They are only around 25 each, so i figured i would try it out. So far so good but I dont knwo how it will hold up to mud and water. The only place i can see where water may try to get in is where the bulb slides in the back. I am prolly going to run some clear silicone around it and it will be waterproof then. All together i have about 70 bucks wrapped up in it. So really its all in what you want. I figured for the money I would go with the Sunpro gauge and if it tears up I wont feel bad, but if a $90 Autometer tore up I would wanna cry.lol In your neck of the woods you should be good to go though.
are there any vent lines to be moved on a snorkle kit efi 750 brute force
brute force 750 snorkel vent lines pics
brute force snorkel vent lines
movie lines that snorkel has been like a snorkel to me
silver brute force
snorkel brute force. what other lines need to be moved?
snorkeling a brute force vent lines
Vent lines camobomb Brute Snorkeling 5 April 23rd, 2008 01:10 AM
vent lines? brutster Brute Engine & Drivetrain 4 April 30th, 2007 06:35 PM
Vent Lines? machinewars Brute Engine & Drivetrain 1 February 22nd, 2007 12:27 AM
