October 22nd, 2008, 12:31 AM
How much top end speed loss with center snorkels?
So i have the bike all apart and ready to install my mains and pilots, and it is all ready for snorkels if i opted to add them. How much speed will i lose on top end roughly? I was going to do 165 front and rear, so what size if i added the snorkels? install the 165's and then pull the plugs to see how shes actin? I really need to know asap if possible how much top end speed you all lost after installing snorkels. Right now with the mains that are in it and the hmf pipe with the dynatek cdi, i am running rich. So what do i need to get and how should my setup be. Its a 07 650I for reference.Thanks.
ohh and one more thing, I will be doing the mimb snorkels.
October 22nd, 2008, 08:35 AM
Re: How much top end speed loss with center snorkels?
You shouldn't lose any top end.* Are you using a 3'' inch or 2'' rubber 90 on the airbox?
3000Lb Viper Winch.
Highlifter Radiator.
Highlifter Springs.
ASR X Series Tierods.
Rox Risers Solex Handlebar.
Drat Fab Lowering Kit.
VFJ Stage 3 Goodness.
EHS Airbox Lid.
Maroon Primary Spring.
</span></span></span>
October 22nd, 2008, 09:16 AM
you will have to jet down from were you are for the snorkles I don't know how much you lose but if you restrict air flow and have to use smaller jets and the dyno numbers are lower then logicaly speeaking you will lose some but how much its probelly diffrent for each machine. If you say lose 5 mph top speed but can hit the mud hole full throttle and not worry then a little loss isn't so bad for your peice of mind
October 22nd, 2008, 11:13 AM
you will have to jet down from were you are for the snorkles I don't know how much you lose but if you restrict air flow and have to use smaller jets and the dyno numbers are lower then logicaly speaking you will lose some but how much its probelly diffrent for each machine. If you say lose 5 mph top speed but can hit the mud hole full throttle and not worry then a little loss isn't so bad for your peice of mind[/b]
Exactly my thoughts too.* Also, ...are you saying that with the stock jets, not the new 165s, you are already running rich? I don't remember you mentioning that in previous discussions.
October 22nd, 2008, 11:40 AM
yeas with the stock, i think we came up with 155's, i am running rich. I am about done putting on the snorkels, waitng for the paint to dry, then i will see how she runs and we'll go from there. I have flynt over on highlifter giving me a hand to. So we should have the beast alive in no time. :goofy:
October 22nd, 2008, 11:44 AM
did you put on your HMF yet? If not you are going to be really rich with everything else stock
October 22nd, 2008, 11:46 AM
Everything is on. Hmf pipe, dynatek cdi and now fixin to be the snorkels with 3inch rubber 90. After i get it wrapped up in a few, i will run it and then pull the plugs and post some pictures of them. Thanks.
October 22nd, 2008, 11:51 AM
If you are already rich with 155's, then 165's will be way too rich.* If you are rich, you need more air, not more fuel.
October 22nd, 2008, 11:56 AM
she is going to stumble on you from to much gas maybe not but I may be wrong
October 22nd, 2008, 01:18 PM
So, if he's already rich with the stock 155s and the HMF & CDI, what could be wrong? He should be way lean before the snorkles. Could be that his needles & seats on the float(s) are warn enough to raise the float levels way up, but too high and the would run over the overflow...what's that..about .080 higher then spec? Is he having that sticky-choke problem? Maybe bad plugged-up air filter?
I mentioned the floats because when mine was brand-spanking-new and on the very first day I took it out, the front float was so high...not enough to overflow..that when I was on it, it pulled enough fuel to actualy fowl the plug completely and drop out. Did it on the flats once, then once on a hill (not the place for that). Took it in and that was what they found.
I'm sure his will work out in time.*
07 brute force 750 lost power after installing snorkels, 3inch snorkle tops, added snorkel lost speed, brute force 08 front clip, brute force 650 top speed, brute force bogging after snorkel, brute force lost speed, brute force running lean, brute force top speed loss, bruteforce center snorkel how to pics, flame custom fenders brute force, how to do the center snorkle on a brute force, install a snorkel on kawasaki brute force 700, kawasaki brute 3 inch snorkel, put a snorkel on now lost top speed, snorkel a 750 brute force 3' center and 1.5 sides, speed snorkel center, what jet kit do i need in 07 650i brute force wiht snorkles, what size 2011 brute force snorkel pipes?, www.hilifter.com; stock brute jetting with snorkels
Power loss
bigpun |
Brute Engine & Drivetrain |
12 |
August 7th, 2008 11:06 PM |
Snorkels center or side
Got Mud |
Brute Snorkeling |
17 |
July 16th, 2008 09:24 PM |
Performance loss with snorkels?
ZOSICK |
8 |
August 23rd, 2007 01:45 PM |
center snorkels
ss340duster |
3 |
August 6th, 2007 11:24 PM |
Power loss!
flashpoint |
3 |
June 24th, 2007 01:13 PM |
