Old October 6th, 2008, 12:57 AM   #1
bustamove's Avatar
Default cvt leaking
i was out in the water i would say about 3/4 up the cvt cover with water. and i was just idling in the water for a bit with my buddy i went to punch the throttle i noticed i had water in my belt. anyone have problems with water getting past the seal?
bustamove is offline
Old October 22nd, 2008, 11:32 AM   #2
Default Re: cvt leaking
I havn't had any problem with the seal, but I did notice I have had to tighten the clamps on the lower boot (air intake) a few times now. Your drain plug still fits tight, right?
Old October 22nd, 2008, 08:52 PM   #3
i had to put alittle chalking around the EBS where it enters the cvt case. it kinda has a crappy bolt pattern. give it alittle shake and see if its lose. after i chalked it out i havent had any problems.
fouz is offline
Old October 23rd, 2008, 10:59 PM   #4
bustamove's Avatar
yes drain plug is tight. thanks for the tips. i will try them asap
rocker cover leaking BRICKLAYER Brute Engine & Drivetrain 12 October 16th, 2008 10:25 AM
leaking seals swabber30 Brute Engine & Drivetrain 0 October 14th, 2008 02:43 AM
Leaking Oil!! Scoobs Brute Engine & Drivetrain 1 July 28th, 2008 12:23 AM
leaking tire bead oohyeah4 General Discussion 5 February 28th, 2008 06:07 PM
Leaking Oil jay_g Brute Engine & Drivetrain 0 February 22nd, 2007 11:58 AM
