You are not very clear here.* What exactly do you mean by cut out?* Did the motor quit or did you just lose power to the wheels?* Also need to know what tires you are running if you feel like you just lost power.*
The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants - Thomas Jefferson
Get an EHS air box lid and duct tape your intake snorkle closed.* You will be all set.* When you hit the water fast, you are getting water into your air box and it is causing the machine to cut out.* With an EHS lid, you can block off your intake snorkle and still have plenty of air for the air box.
Get an EHS air box lid and duct tape your intake snorkle closed.Â* You will be all set.Â* When you hit the water fast, you are getting water into your air box and it is causing the machine to cut out.Â* With an EHS lid, you can block off your intake snorkle and still have plenty of air for the air box.[/b]
Also steam is alot of the issue from when you hit the water
You can also just seal up your airbox better.* You can take some silicone and apply it around where the lid goes.* Let it sit for abut 10 minutes and gets tacky.* Apply some kind of lubricant around where the lid meets the airbox so it wont stick to it.* Then put the lid back on and clamp it down.* Leave it there for a few hours.* Then when you take it off the silicone you put down will form a nice tight seal.*
I would also put die electric grease on your spark plugs.* would also run your carb and diff vents up to your pod.*
the problem is the carb canister in front of the airbox, its a white canister that sits right in front of the airbox. you need to take that canister out and put a T in it and run it up to the pod.* check on highlifter in the kawi tips for how to do it.* mine did that till i changed this
the problem is the carb canister in front of the airbox, its a white canister that sits right in front of the airbox. you need to take that canister out and put a T in it and run it up to the pod.** check on highlifter in the kawi tips for how to do it.* mine did that till i changed this[/b]
Yep, The vent lines go into a white canister, then one line comes out. The canister is screwed to the front of the airbox. Once you take it off of the airbox you will see a hole in it. Either plug the hole with silicon or buy a "tee" fitting to replace the canister. Route the vent line up to the pod & ziptie it off. Hope this helps.
I always wondered why mine would do that when I hit water too fast. I always thought it was from water getting in the airbox, but never saw any in there or come out of the drain.* Thanks guys :)
__________________ 06 750 (Silver) Dynatek CDI |TwinAir Filter | Catch Can | PrecisionPro Stabilizer | Perma-Cool Oil Cooler | Diamond "G" Tie Rods & Ends | Energy Swaybar Bushings | OMI Stem Bushing | Ricochet Skid Plates | HL Bumper | Direction2 Overfenders Vids On Vimeo | Vids On Contour | Vids On You Tube
