August 16th, 2008, 02:52 AM
Ram air using snorkeling
I read that ram air using air intake snorkel was a good thing. Well, I totally agree. Today i took off the last 45 elbow of the snorkel and turned the remaining 45 towards the front of the bike. Man, oh Man, just like breathing in a new life. Those carbs loved the air, the faster I went, the better they worked. Gas mileage was almost doubled.
Problem being, cannot use this snorkel in bad weather. I guess I can go back to original snorkel configuration* on those crappy days. Kawi power is still better than most, even when starved for air.
'06 750i
26" 589's
Garmin GPS 60C
2up seat / fender guards, foot pegs
Moose Power Mod
August 16th, 2008, 02:56 PM
Re: Ram air using snorkeling
Like you said sounds like a good deal until it rains and you have to change back.*
2008 Team Green Brute Force 750:
SS 2" Lift, 1.5" Spacers, ITP SS112s, 29.5 Outlaws,
3000lb. Winch, HMF Swamp Series,
EPI Maroon/Lime Green, Center Snorkels,
Radiator Relocated
August 16th, 2008, 03:32 PM
I have had my snorkel like this since day 1. But you are right even if there is just mist out the bike wont run right with the snorkel facing the front.
Brute Force 650 sra
KFX V-Force 700
August 17th, 2008, 04:59 AM
lol i just left my top 45 loose.. so if im splashing through puddles i face it too me. if im just on the loggin roads and face it out works like a charm.
Jetting after snorkeling
Muddy Brute Force |
Brute Engine & Drivetrain |
4 |
March 1st, 2009 11:41 PM |
snorkeling 08 efi brute
bushhog750 |
4 |
October 1st, 2007 11:59 PM |
