Old July 19th, 2008, 12:45 AM   #1
4byrookie's Avatar
Default types of hose to use?
I am planning on snorkeling in a couple next weekend as it sucks in water way to easy and I was wondering if it is better to use all pvc style tubing and angles or is it just as good to use some sort of flex hose? The flex hose you could just bend where it needed to go I would think but am not sure if this would work as well. Also how much difference is there between the 07 and 08's for doing the snorkels? Would the mudinmyblood setup work properly for the 08 or would it half to be modified some? Thanks for any help in advance.
2008 750 Brute Force, Aluminum skids, 1.5" lift,*Highlift springs, 28" Zillas on 14" SS212s & chrome skull caps, HL triple core rad in stock location, HMF Swamp Series, Power Commander III, Maroon Primary spring, Symtec 4 zone H/T warmers, Custom shift knob
4byrookie is offline
Old July 19th, 2008, 11:53 AM   #2
The Mudinmyblood will work fine.
06' 650 Brute SRA
Radiator Relocate, Snorkeled, Custom Skids,
27" Mudzillas,2" Lift
jakedogg is offline
Old July 19th, 2008, 12:12 PM   #3
BassMaster's Avatar
MIMB setup will work fine for the 08. Go to the topic about the ninja snorkels if you want to use flex hose.
08 Brute Force 750i
BassMaster is offline
Clear Radiator Hose? Waterfreak66 Brute Engine & Drivetrain 15 July 26th, 2008 10:30 PM
Looking for hose size? Sasquatch Brute Engine & Drivetrain 5 April 30th, 2007 07:19 PM
What size vacuum hose for the carbs? machinewars Brute Engine & Drivetrain 1 February 23rd, 2007 08:00 PM
