April 26th, 2008, 08:23 AM
Secondary clutch spring compressor tool
There was some pictures and instructions of a home made tool on here a while ago, but now I need it, I cant find it. from memory I think Adirondack man posted it, Anyone know where it is?
07 Brute Force 750i
Muzzy Full Exhaust, Dynatek CDI,
26" Swampfox Plus, EPI Maroon primary
3500 lb winch, Aluminium skids, Snorkles
HID conversion
April 26th, 2008, 09:05 AM
Here is a picture of the one I made. Give you an idea. Good luck
April 26th, 2008, 10:01 AM
Here is a picture of the one I made. Give you an idea. Good luck[/b][/b]
I some i can e-mail you.
2005 BRUTE FORCE 750
29.5 Outlaws, spyder wheels, Custom Skid Plates,
Full Big Gun exhaust, Dyno jet kit,
Custom snorkel, K&N, EDI extreme clutch kit.
April 26th, 2008, 10:10 AM
Thanks Kabruta, That looks easy, springs are in the post! I take it the cutout section is to get to the circlip?
07 Brute Force 750i
HID conversion
April 26th, 2008, 10:39 AM
You need a length of threaded 5/8" rod, about 15" long, two nuts, two large washers, one piece 2" pvc end cap. Cut out a piece of the end cap to allow pliers to go in to remove circlip on clutch. Here is a picture. Total cost right around $5.00.
April 26th, 2008, 10:40 AM
Pic of tool all together.
April 26th, 2008, 12:09 PM
Yeah its a very simple tool. I just used stuff I had in the garage. A-Man's tool will work just as good. Good luck
clutch spring compressor tool kfx 700, homemade secondary clutch compression tool pics, homemade secondary clutch compressor, homemade spring compressor for brute force, polaris sportsman clutch spring compression tool, secondary clutch spring compression tool, secondary clutch spring tool, spring compression tool for secondary clutch
