Old August 31st, 2007, 06:32 PM   #1
Default Brute big bore kit
I was reading about four stroke tech's big bore kit for the brutes, and am wondering does anyone have this mod?? By reading about it I am guessing that it would make my 650 to a 800... or so?? The kit includes: pistons, rings, pins & clips and head gaskets. Is that everything that is needed?
07 Brute Force 650i
27" Outlaws, Rattlesnake wheels, SSATV lift,
HMF Exaust, Moose jets & Module, 1.5" Wheel spacers
flashpoint is offline
Old August 31st, 2007, 06:59 PM   #2
I have the 840 kit in my 750 and let me tell you, it is insanely powerfull.
The cost for the advertised kit is not all inclusive. You will also need cams, valve springs, and to have your cylinders bored and Nik-A-Siled.
Kit listed $470
2 cams $400
Valve springs $190
Bore & Nik-A-Sil $460
Cylinder base gaskets from dealer $10
If you choose to buy the cores and not return your stock cylinders and cams you will pay for the cores.
Cam cores $300
Cylinder cores $600
Total without cores $1530
Total with cores $2430
Then, if you really want to wake it up and get all you can out of the kit.
Full Muzzy exhaust $435
Twin-Air power flow kit $300
EHS air box cover kit $90
Total $3255
Another guy you may want to check with is Flynt Custom Performance. I have heard he makes a he** of an engine as well and I have spoke with him and he is quite knowledgeable about the Kaw V-twin.
Boloiii is offline
Old August 31st, 2007, 08:50 PM   #3
Micky at Four Stroke Tech is having a 20 percent off sale this month.Now is the time to do it.I have the 840 kit in my bike and my best 300ft dirt drag times is a 4.90.I would buy the kit from Micky and have a local shop put it together.It does get expensive with the extra stuff you will want.
WVSwampDonkey is offline
Old August 31st, 2007, 11:53 PM   #4
BRUTE650's Avatar
Will this kit work in my 650 to make it an 840? My engine blew up on me so time for a rebuild and well, go big or go home.
650 Brute SRA
27' Executioners
HMF Penland
Moose Module
Snorkeled
1 5/8 spacers per side
BRUTE650 is offline
Old September 1st, 2007, 04:22 AM   #5
It will with a 700 crank.If you use the 650 crank I think it would be a different size but still a strong motor.
Old September 1st, 2007, 10:56 AM   #6
That sounds great, have to put some money together first. I thought that the kit price was too good to be true.... Thanks for the help.
07 Brute Force 650i
Old September 2nd, 2007, 07:17 PM   #7
There's Fundy Performace Sports in NS Canada also.
Do your homework and call around first.
Camo is offline
Old September 7th, 2007, 12:25 AM   #8
I have the 650 engine in my arctic cat 650 v2 I did the FST 765 kit with the brute force crank making it an 800. what a difference WOW!
Arctic Cat 650 v twin
Snorkels
EPI Clutch Kit
Blown Motor
crazyyooper is offline
06 brute force big bore kit
2005 brute force motor rebuild kit four stroke tech
2005 kawasaki brute force 750 big bore kit
2007 big bore kit brute force 750
750 brute force big bore kit
765 big bore kit
athena big bore kits brute force
big bore kit for 07 brute force 650i
big bore kit for 2008 brute force 650i
big bore kits for brute force 650i
brute force 650 big bore kit
brute force 650 piston kit
brute force 650i big bore kit
brute force 650i big bore kits
brute force 840 big bore kit
brute force big bore kits
wholesale brute force big bore kits
FPS STD bore kit Drew T Brute Engine & Drivetrain 1 November 7th, 2007 01:25 AM
To Bore or Not to Bore snow force Brute Engine & Drivetrain 5 December 18th, 2006 09:02 PM
