Old August 26th, 2007, 06:47 PM   #1
Default front diff locker wont disengage
My front diff locker wont disengage. I pulled off the cable and it is working fine, the 4x4 engages and disengages fine also. Has anyone else had this problem before? What was the fix? Thanks
mattloxfl is offline
Old August 27th, 2007, 11:36 AM   #2
Does the arm move on the front diff when you release the lever? Is your cable set too tight?
Boloiii is offline
Old August 27th, 2007, 04:05 PM   #3
The arm moves and I have the cable completely out right now. Still won't disengage.
Old August 27th, 2007, 04:31 PM   #4
It should take about 15 ft.lbs. to turn one wheel while the other is locked from turning without the diff. lock engaged and it should be 116 or higher to do the same with the diff. lock engaged. Any idea how much yours takes to turn one and not the other.
Also, make sure the punch mark on your shaft is ligned up with the punch mark on the lever. If they are not it could be holding it on.
Were you stuck and slipping it a bunch that it may have "welded" itself?
Boloiii is offline
Old August 28th, 2007, 03:50 PM   #5
I know its stuck, its almost impossible to turn while moving. I was in some deep mud when the problem came up, the spider gears are probably screwed up or the mechanism that engages the locker is bent internally. I was hoping someone would have a simple fix, its apparently not simple, i'm going to have to tear apart the front diff to see whats going on. Oh well thats part of the fun. thanks for the input boloiii
Old August 28th, 2007, 04:05 PM   #6
I hope you find something simple, let us know what you find. Good luck.
Boloiii is offline
front diff lock wont disengage
07 BF front diff dieselskinner Looking To Buy 1 May 16th, 2009 01:16 PM
Front Diff jakedogg Brute Engine & Drivetrain 9 February 18th, 2008 06:39 PM
front diff scrat600 Brute Engine & Drivetrain 7 February 10th, 2008 08:51 PM
Front Diff removal Gman77 Brute Engine & Drivetrain 2 October 23rd, 2007 06:32 AM
Front diff 05-BF-750 Brute Chassis & Electrical 4 April 23rd, 2007 03:01 PM
