Old August 16th, 2007, 09:36 PM   #1
Default 06 BRUTE 750 BROKEN FLYWHEEL TEETH
anyone have the flywheel teeth break on them for no apparant reason?? mine has around 1200 miles on it........
dragster5408 is offline
Old August 17th, 2007, 12:36 PM   #2
does it have the dyna tech chip in it
mbeck is offline
Old August 18th, 2007, 11:21 PM   #3
yes it does. iguess it has to much timing advance during cranking? it was back firing out the exhaust before it happened.i replaced the fly wheel it is still backfiring.i'm guess lean mixture because if i put the choke on its not as bad?? any ideas?
Old August 31st, 2007, 11:05 PM   #4
STOGI's Avatar
This is a problem mostly seen on bikes with a VDI set with to much initial advance. You normally don't have this problem with the Dyna. They start out at 5-6* I believe it is. Heck, I run a 6* key with a module and that starts out at 11* right of the bottom and doesn't cause this problem
BF750 Built For Business
Stock is for pansies.
STOGI is online now
Old September 4th, 2007, 01:09 PM   #5
I know the dealer in town said that they have had problems with the dynatech chip taking out teeth on the starter drive.Something about it kicking back when it stalls.
mbeck is offline
does flywheel teeth break
flywheel teeth broken
what happen flywheel teeth breaks
Wanted Broken Brute/Prairie Dyna CDI uhittheuglytree Quads & Parts For Sale 3 March 21st, 2009 02:39 PM
broken CV sackamous Brute Engine & Drivetrain 0 February 10th, 2008 04:35 PM
Broken Valve Stem Azazeal Brute Tire & Wheel Combos 3 April 8th, 2007 01:07 PM
