Old August 12th, 2007, 01:33 PM   #1
Default what color springs
Just ordered 27" mudlites and a dynatek for my 650 SRA. This brute is used for trail riding, pulling a small trailer and occaisionaly mud. What springs would make the most of this set up?
Appreciate any help.
scbrute
scbrute is offline
Old August 12th, 2007, 08:15 PM   #2
scbrute[/b][/b]
hey highlifter makes a pretty good set of springs and the pretty affordable
deadeyedick71730 is offline
Old August 12th, 2007, 11:24 PM   #3
scbrute[/b][/b]
I got 27" swamplites and a dynatek on my 750i and but in a pink and almond from epi works great.
Cumminsnorth is offline
Old August 13th, 2007, 04:05 PM   #4
05-BF-750's Avatar
I have 26" swamplites with the pink and almond set up. I lost to much topend when I installed the pink spring think I might take it out and put the stock back in. Keep in mind that the SRA brute has way different stock springs then the 750 IRS has. So the pink and almond may work different in the SRA module.
Brute Force 650 sra
KFX V-Force 700
05-BF-750 is offline
Old August 13th, 2007, 09:32 PM   #5
I have played with springs all weekend in my 650i and ended up settling on the stock primary and almond secondary. The pink turned low into a granny gear and high into faster low gear. The revs were through the roof in high but the topend was terrible and I couldn't tell much difference in acceleration. I have several other primary springs to play with the next time I have time monkey with it.
I put the black secondary in my wifes 650sra and left the primary stock for the time being. It seems to work great with the 26" MSTs and moose module.
Claydigger is offline
Old August 15th, 2007, 11:40 PM   #6
Thanks, I ordered pink and almond....and a primary puller...I hope this is not going to be too difficult of a job.
scbrute is offline
Old August 18th, 2007, 11:47 AM   #7
BluelightSpecial's Avatar
Thanks, I ordered pink and almond....and a primary puller...I hope this is not going to be too difficult of a job.[/b][/b]
Its not hard at all. I installed the Almond secondary, with the bike still in the bed of my pick up! Make sure you oil the threads of your primary puller with wd-40, pb blaster, etc. also the primary will make a loud pop when it finnally breaks free. You will think you broke it, it sounds that bad, but you'll be ok. I personally like the almond secondary/stock primary configuration. Alot snappier, and the belt hardly slips at all. Let us know how the pink primary is, after the install. Good luck!!
2006 BruteForce 650i
26" Mudlite XTR's, wrapped around 12" ss112 wheels
Warn 2.5ci
Almond secondary
Auto meter temp guage
BluelightSpecial is offline
Old August 20th, 2007, 10:14 PM   #8
Thanks bluelight, i have that first time phobia...I have the parts, just haven't had the time to do it. I got stuck in some really bad mud yesterday, and i am afraid i smoked a belt in the process.
scbrute is offline
what color spring bruteforceracer Brute Engine & Drivetrain 14 May 30th, 2009 01:36 AM
Help me choose a color BrianMc Brute Chassis & Electrical 10 February 14th, 2009 10:43 PM
Color Code? bigredz350 Brute Chassis & Electrical 1 January 21st, 2008 11:56 AM
what color spring for polaris ryanracing Brute Engine & Drivetrain 0 September 2nd, 2007 10:01 AM
Help me decide on COLOR! bruteboy101 General Discussion 20 February 17th, 2007 02:07 AM
