July 16th, 2007, 07:29 PM
2007 650 SRA secondary spring
I just changed the secondary spring in my 07 650 SRA to an Almond. It had a yellow in it before. When I went to change it I was thinking the springs would be the same as in my 750. My question is did I put in the wrong spring for the 650 SRA? I didn't really feel much of a difference between the Almond and Yellow. Im running ITP type 7 wheels with 25" mudlite XL's. Looking to get lots low and mid power. What should I have gone with?
Brute Force 650 sra
KFX V-Force 700
July 18th, 2007, 06:45 PM
Come on guys someone has to know something? Really need some help here.
Brute Force 650 sra
KFX V-Force 700
July 18th, 2007, 06:53 PM
I went from a stock secondary to the almond and noticed a definite difference on the bottom end, not sure from yellow to almond though. I'm running 27" Mudbugs.
2005 BF 650
Moose Mod
more to come ....
July 18th, 2007, 10:44 PM
By changing the secondary you are affecting belt grip and back shifting mainly.
If you want low to mid you will want to change the primary. I am not sure what the SRA has for springs though.
Also the springs are quite different between the 750 and the 650. The 750 has a much heavier spring in the secondary for higher belt grip.
I would give either VforceJohn or EPI a call and see what they would suggest.
July 19th, 2007, 03:03 PM
Yea the almond seems heavier then the stock spring. So I think I will keep it and try changing the primary next. thanks for the help.
Brute Force 650 sra
KFX V-Force 700
August 28th, 2007, 10:04 PM
05, I replaced the primary spring and secondary spring with a pink and almond. My original was a black primary and yellow secondary. 05 650 SRA. It has 27" mudlites and a dyna....In high with my 325lbs, it will throw you off the back. IMO it pulls a lot harder than it did stock with the 25" dunflaps.
2007 brute force 650 sra
