Old June 25th, 2007, 08:32 PM   #1
Default Over Heating!!
Guys I rode for a/b 45 minutes yesterday and my machine started running hot. It shouldn't get hot that quick should it? Any feed back is welcome!! Thanks!!
06 750
27" swamplites
2" lift
moose power module
warn rt 25
muddydog750 is offline
Old June 25th, 2007, 10:02 PM   #2
The little thermometer on the display started blinking. Is that what your talking a/b?
06 750
27" swamplites
2" lift
moose power module
warn rt 25
Old June 25th, 2007, 10:17 PM   #3
Yes I belive that is what he is talking about. Did you look to see if your radiator was clogged? Also check to see if your fan is coming on, and that you have fluid in your resivoir. No your bike should not overheat that quick if ever, if it has the appropriate operation.
07 Brute Force 650i
27" Outlaws, Rattlesnake wheels, SSATV lift,
HMF Exaust, Moose jets & Module, 1.5" Wheel spacers
flashpoint is offline
Old June 25th, 2007, 10:20 PM   #4
sounds like the thermostat is stuck or the coolant is low or empty.
2007 Brute Force 750
2007 DRZ 400
www.myspace.com/bacord
Follow me on SPOT TRACKER
Seca_ is offline
Old June 25th, 2007, 10:30 PM   #5
Got plenty of cooilant,fan is running. I'll check for the clog tomorrow. If it is the thermo will it be covered under warranty.
06 750
27" swamplites
2" lift
moose power module
warn rt 25
Old June 27th, 2007, 03:56 PM   #6
Got plenty of cooilant,fan is running. I'll check for the clog tomorrow. If it is the thermo will it be covered under warranty.[/b][/b]
If not it is cheap and easy to replace.
2007 DRZ 400
Seca_ is offline
Old August 28th, 2007, 11:14 PM   #7
Anyone running WaterWetter? Might be worth trying to help with the temps.
Jared Smith
'07 Thunder Blue 750i
Pen-Lock,Sway bar removed,1.75" spacers, 3Klb winch
8898jsmit is offline
Old August 29th, 2007, 01:43 PM   #8
I would deffinately check your radiator for clogs. I would also check the fluid in the radiator not just the resivoir.
8898jsmit,
I am running water wetter. It seems to help a little. It doesn't help if i have a clog raditior though. Good ole mud!!!
2007 Brute, 29.5 x 10 Laws
Dynatek CDI, EPI clutch kit, LRD Torc Exhaust,
Custom center snorks, 2.5" spacers on all 4's
2008 Renegade 30" Silverbacks
HMF, PCIII, Custom Center Snorks, some clutch work
JLUKE is offline
Still Over Heating after HL Rad Relocate Dagan Brute Engine & Drivetrain 11 May 13th, 2009 05:31 PM
Heating up 4byrookie Brute Engine & Drivetrain 10 August 7th, 2008 03:55 AM
Over Heating ? bruteken Brute Engine & Drivetrain 8 May 1st, 2008 08:17 PM
BRUTE HEATING UP supertone Brute Engine & Drivetrain 4 April 30th, 2007 01:54 PM
OVER HEATING HELP steve Brute Engine & Drivetrain 6 March 14th, 2007 10:48 PM
