May 22nd, 2007, 11:20 AM
Finished stock exhaust mod
Well, I finished the 2007 Brute 650 SRA stock exhaust mod yesterday. It now has a very nice deep tone to it. I almost think it sounds better then my HMF on the 750. It was all rather ez to do just took a little time cause I did all this without cutting the end cap off.
Brute Force 650 sra
KFX V-Force 700
May 22nd, 2007, 11:31 AM
Brute Force 650 sra
KFX V-Force 700
May 22nd, 2007, 11:33 AM
Brute Force 650 sra
KFX V-Force 700
May 22nd, 2007, 11:35 AM
Brute Force 650 sra
KFX V-Force 700
May 22nd, 2007, 01:11 PM
What did you do? It looks like you just removed the spark arrester and drilled holes threw the baffle. How far down did you drill the holes? Did you have to rejet? Does it seem to run alot better? Better than HMF? I don't mean to sound like I'm drilling you I'm just curious. I want to mod mine as well. Thanks in advance.
2007 Brute, 29.5 x 10 Laws
Dynatek CDI, EPI clutch kit, LRD Torc Exhaust,
Custom center snorks, 2.5" spacers on all 4's
2008 Renegade 30" Silverbacks
HMF, PCIII, Custom Center Snorks, some clutch work
May 22nd, 2007, 10:05 PM
What did you do? It looks like you just removed the spark arrester and drilled holes threw the baffle. How far down did you drill the holes? Did you have to rejet? Does it seem to run alot better? Better than HMF? I don't mean to sound like I'm drilling you I'm just curious. I want to mod mine as well. Thanks in advance.[/b][/b]
Let's see.... Yes, I had to rejet. I drilled through the first and second baffle. Yes, It seem to run a little better. I also have a 2005 750 With a HMF exhaust on it, I was saying I think the stock exhaust on my 650 SRA has a better sound then my HMF pipe. Anything else?
Brute Force 650 sra
KFX V-Force 700
May 23rd, 2007, 08:14 AM
Good job.....looks nice...
BF750 Built For Business
Stock is for pansies.
12 hole mod., 650 brute force stock exahust, brute 650 sra modify stock exhaust, brute force 650 stock exhaust mod, brute force 750 exhaust mod, brute force 750 stock exhaust mod, brute force stock exhaust mod, cutaway view of stock brute force exhaust, how to modify stock brute force exhaust, kfx 700 factory exhaust modified, kfx 700 stock exhaust modifications, what does the 12 hole mod do?, wisco piston kit for brute force do you have to rejet them
