Brute Central Forums » Brute Forums » Brute Engine & Drivetrain » STOCK EXHAUST MODIFIED AND HMF GONE........
Old May 5th, 2007, 02:26 PM   #1
STOGI's Avatar
Default STOCK EXHAUST MODIFIED AND HMF GONE........
After being told by my wife that she wasn't going to ride with me again until I got rid of " that loud a** pipe" and being told by the rest of the family that they were going to take a no confidence vote on me being the leader of the pack I have had to take off the HMF. And..... I have to agree with them. It had gotten so loud that it was annoying to be around.
I had been reading some post about modding the stock pipe. Some talked about drilling holes and one even suggested that blasting the packing out with a pressure washer would give it more power....???
SOOOOO..........I pulled the old stock pipe out of the shed . I cut the weld of the end cap and ground out the plug welds that held in the collecter for the silencer. I also ground out the plug welds for the turbine. I pulled out the silencer and turbine. I cut the silencer off the end cap . Then I lengthened the finns on the turbine using a cuttoff wheel and open them up by changing the pitch with a pair of pliers. Behind the turbine is the baffle chamber. I left it intact but I did drill 12 3/8" holes in it inline of where the headers inter the canister. This will help it flow more but keep the sound level down. I then inserted the modified turbine and plug weld it in it's original position. I welded the end cap back on minus the silencer and collector. Then I welded the snorkel on. I gave it a thick coat of 1500* exhaust flat black and installed.
MAN>>>>THIS THING SOUNDS 100% better. It has a very deep throaty tone and will not ring your ears like the HMF. It's a totally different sound then the HMF ever made. It sounds like a deeper throatier Muzzy.
Performance wise it brought back allot of the bottomend torque and doesn't revout as quikly as the HMF. It restored some of the back pressure the motor needs to produce good torque. Feels really strong and the jetting seems to be about right.
After doing this I would have to say this is one of my 3 top favorite mods. The others being the Moose/6* key combo and removing the swaybar. And the HMF being the worst...A big waste of money. IMO
Later on today I'll have some pics of the process posted .
BF750 Built For Business
Stock is for pansies.
STOGI is offline
The Following 2 Users Say Thank You to STOGI For This Useful Post:
jgcobra (December 3rd, 2009), ronford 750 (July 8th, 2010)
Old May 5th, 2007, 05:41 PM   #2
BRUTE650's Avatar
Just got back from my first ride with the penland, as good as it sounds, it does give a headache, so I'll probabaly be putting the quiet core in soon.
650 Brute SRA
27' Executioners
HMF Penland
Moose Module
Snorkeled
1 5/8 spacers per side
BRUTE650 is offline
Old May 5th, 2007, 05:42 PM   #3
cdl
Stogi:
Wow - sounds great! Looking forward to seeing the photos... do you think this would work for the BF650i? What is the 'removing sway bar mod you mentioned?
I'm new to the scene and looking for tips - I can't believe how much I like my 650i!
thanks,
CDL
2007 BF650i Black
Warn 2.5
26" IPT XTR's
cdl is offline
Old May 5th, 2007, 08:07 PM   #4
STOGI's Avatar
Here's the link to the pics http://photobucket.com/BF750exhaustmod
STOGI is offline
Old May 7th, 2007, 08:01 PM   #5
STOGI's Avatar
I've made one more change at the request of the little lady( What would I do without her??) She said it sounded good but she hates it being in her ear sooooo....I cut the snork off flush with the end of the canister and secured the endcap turn down to it with hex head drill point screws . Sounds even better!!!!! The snork gave it a "rattatat" sound now it's a nice clean rumble. Being that the only reason I put the snork on the HMF was to try protect the packing, I don't think it will be missed. Good thing about this is it can be washed out easly. Just pull the plug and flush it out.
STOGI is offline
Old May 7th, 2007, 11:20 PM   #6
05-BF-750's Avatar
Awesome pix
Brute Force 650 sra
KFX V-Force 700
05-BF-750 is offline
Old May 8th, 2007, 08:06 AM   #7
Stogi:
CDL[/b][/b]
check out this link: http://www.brutecentral.com/forum/in...showtopic=2197
07 BF 650i
112ss
26" Mudwisers
Dynatek CDI
Swaybar Removed
mAtTy is offline
Old May 8th, 2007, 08:16 AM   #8
STOGI's Avatar
Stogi:
thanks,
CDL[/b][/b]
This should work on the 650i.......Removing the swaybar is a mudders modification. I lets the rear be truly independent . If you like fast trail rides and cornering this wouldn't be for you
STOGI is offline
Old May 8th, 2007, 01:11 PM   #9
You ended up doing almost exactly what I ended up with after 3 rebuilds of my stock exhaust. Only difference is I also drilled holes in the turbine. Sound is perfect, nice low throaty sound without alot of volume. I think it acutally flows BETTER than the HMF because the bike has taken a much larger jet than HMF reccomends. You cannot beat the price, and it's great when something free acutally works better than the aftermarket counterpart.
ojcool is offline
Old May 8th, 2007, 07:34 PM   #10
STOGI's Avatar
You ended up doing almost exactly what I ended up with after 3 rebuilds of my stock exhaust. Only difference is I also drilled holes in the turbine. Sound is perfect, nice low throaty sound without alot of volume. I think it actually flows BETTER than the HMF because the bike has taken a much larger jet than HMF recommends. You cannot beat the price, and it's great when something free actually works better than the after market counterpart.[/b][/b]
At first I thought about just drilling holes all the way through it but after I got the silencer out and shown my flash light into the turbine to see what was back there I decided on pulling out the turbine and opening it up some and then drill the holes where some of the exhaust would have a straight shot out. You can see in the pics that I drilled one hole then stopped The turbine actually directs the exhaust towards the center of the end cap so it doesn't just hit the back of canister and bounce around.
My biggest gripe about the HMF was it didn't hold up to the mud.......Of course they have been trying to tell us that.
STOGI is offline
brute 650 sra modify stock exhaust
brute force 750 with exhaust baffle removed
brute force modified stock exhaust
brute force stock exhaust mod
cutaway view of hmf penland pro
do hmf pipes have baffles
gut brute force muffler
gutting bruteforce 750 muffler
how to take out exurst baffel 750 brute force
modifie stock brute force exhaust
modified brute force exhaust
modified brute force pics
modify exhaust for brute force
modify stock wolverine exhaust
modifying brute force muffler
why does my hmf exhaust whistle
worldofbrutes
stock exhaust mod? bctoasters Brute Engine & Drivetrain 5 March 11th, 2008 09:09 AM
stock exhaust mod...any clip? bctoasters Pictures & Videos 1 March 9th, 2008 06:50 PM
Cutaway of stock exhaust Coastie Brute Engine & Drivetrain 0 January 27th, 2008 07:47 PM
Stock exhaust shield KSMITH700 Brute Engine & Drivetrain 2 May 30th, 2007 06:52 PM
Finished stock exhaust mod 05-BF-750 Brute Engine & Drivetrain 6 May 23rd, 2007 08:14 AM
